Problem with no-ip script update
Hi All,
I have RB 6.13 installed on my MT.
I use this script for updating my no-ip dyndns account.
http://forum.mikrotik.com/t/dynamic-dns-update-script-for-no-ip-dns-for-router-os-v-6-7/73699/1
but i have a problem with the update.
when my ip is changed i can see in the log that the script get the new ip adress and the update intervall tells me that no update is needed because the IP is equal to the current ip.
when i check my ip on the no-ip website i see that there is still the old ip adress.
so i think the update script is not work very well.
when i reboot my MT the update is still ok.
can anybody help me.
at the moment i have no idea whats wrong.
thank you very much.
mandagora
the script made for using fetch present everytime the same error: “update\3Fmyip” is wrong, must be writed INSIDE THE SCRIPT, NOT ON THE CLI, as “update?myip”
FETCH DO NOT UNESCAPE THE URLS!!!
Before post question, use search function:
http://forum.mikrotik.com/t/problem-with-script-for-no-ip-info-after-update-to-6-12/76934/2
Good Morning rextended,
Thank you for your answer.
I will try this.
And sorry. I have looked for it but could not find anything.
bye
mandragora
