I’ve been using Dude version 6.40rc24 on CHR and week after install it crashed without any reason. The machine is virtualized in VirtualBox. After restarting it all started properly but something weird happend with Services > Outages. All devices on map are red flagged and signed as “active” in outages. So they should be in non working condition but if you look at the map, then everything is “green”. Today is 10.07.2017 and Outages says that my devices are “active” in 15.07.2017. That day didn’t happend yet I cannot “remove resolved” them in any way. The time counter ticks downwards so I guess if they go to 00:00:00 they will disappear and start working normally.
Is there any way to fast foward it? I’ve tried to manually change date and yes, they’ve disappeared but then Outages stopped working. Nothing was showing up there. So I guess the counters must really go down to 00:00:00.
Now I’ve downgraded CHR to 6.39.2 stable version because previous 6.40rc24 crashed again just week after the last crash (same day as before – it was sunday).
Yes, I’ve had all the problems like this too using CHR on Virtualbox. Nobody answered my previous thread about it.
The time difference gets worse with every VM boot, but restarting the host machine seems to reset it to only a small value in to the future. It is still wrong though.
The ‘solution’ to the Dude database problem is to disable it before rebooting, then re-enable it after the NTP client has put the time right.
Yes I saw that thread. Also I’ve reported this problem to MT support and they confirmed a bug with CHR’s system clock and Virtualbox. This will be fixed.
about the time issue just remove the NTP Package from the system then configure SNTP client with the another NTP server , regarding the outage if your database backup its from old versions and you migrated it to new dude version you must delete some old files that you are not need them bu accessing the data base using FTP
