I am new to MikroTik routers and I have problem with port forwarding.
Want to ssh my Raspberry PI outside my local network but after trying to access the MikroTik terminal is accessed from outside.
Seems the NAT config is not redirecting to 192.168.0.155 where the Raspberry PI is.
Here is my config →
# aug/04/2022 21:30:01 by RouterOS 6.48.6
# software id = H8K9-XIZT
# model = RB760iGS
# serial number =
add name=bridge1
set [ find default-name=ether1 ] mac-address=D8:47:32:05:3C:B4
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.0.10-192.168.0.254
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=sfp1
/ip settings
set accept-redirects=yes accept-source-route=yes
add interface=ether1 list=WAN
add list=LAN
add address=192.168.0.1/24 interface=bridge1 network=192.168.0.0
/ip dhcp-client
add disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.0.252 client-id=1:44:5c:e9:7c:a1:3c mac-address=\
44:5C:E9:7C:A1:3C server=dhcp1
add address=192.168.0.155 client-id=1:b8:27:eb:81:5b:13 mac-address=\
B8:27:EB:81:5B:13 server=dhcp1
add address=192.168.0.0/24 gateway=192.168.0.1 netmask=24
set servers=0.0.0.0
add action=dst-nat chain=dstnat dst-address=31.13.xxx.xx dst-port=22 \
in-interface=ether1 protocol=tcp to-addresses=192.168.0.155 to-ports=22
/ip service
set telnet disabled=yes
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Sofia
/system identity
set name=RouterOS
Thank you in advance !
