I have followed the thread.
http://forum.mikrotik.com/t/proxy-arp-solution-solved-howto/3130/1
And all is working really well, but
When I go to whatismyip.com I get the results pictured below.
What is up with the PROXY?
Here are snips from the MT config.
[admin@MikroTik] > /ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 69.217.1.66/26 69.217.1.64 69.217.1.127 WAN
1 ;;; hotspot network
10.5.50.1/24 10.5.50.0 10.5.50.255 HOTSPOT
[admin@MikroTik] > ip route print
C - connect, S - static, r - rip, b - bgp, o - ospf
# DST-ADDRESS PREFSRC G GATEWAY DISTANCE INTERFACE
0 ADC 10.5.50.0/24 10.5.50.1 HOTSPOT
1 A S 69.217.1.80/32 10.5.50.1 r 10.5.50.1 HOTSPOT
2 ADC 69.217.1.64/26 69.217.1.66 WAN
3 A S 0.0.0.0/0
[admin@MikroTik] > /ip web-proxy print
enabled: no
src-address: 0.0.0.0
port: 3128
hostname: "proxy"
transparent-proxy: no
parent-proxy: 0.0.0.0:0
cache-administrator: "webmaster"
max-object-size: 4096KiB
cache-drive: system
max-cache-size: none
max-ram-cache-size: unlimited
status: stopped
reserved-for-cache: 0KiB
reserved-for-ram-cache: 349184KiB
[admin@MikroTik] > /ip proxy print
enabled: no
port: 8080
maximal-client-connecions: 1000
maximal-server-connectons: 1000
[admin@MikroTik] ip hotspot profile> print
Flags: * - default
0 * name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot
rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0
login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no
use-radius=no
1 name="hsprof1" hotspot-address=10.5.50.1 dns-name=""
html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=0s
split-user-domain=no use-radius=yes radius-accounting=yes
radius-interim-update=received nas-port-type=ethernet
[/url]
