Problem with queue script v3 !!!
Script works fine on 2.9 but no doesn,t work. Where is mistake ?
:foreach m in=[/queue simple find target-address=10.1.91.9/32] do {:put $m;};
I can’t find queue.
[admin@rtr-91] /queue simple> pr
0 name=“10.1.91.9” target-addresses=10.1.91.9/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both
priority=8 queue=default-small/default-small limit-at=2880000/3180000 max-limit=2900000/3200000
total-queue=default-small
[admin@rtr-91] /queue simple> :foreach m in=[/queue simple find target-address=10.1.91.9/32] do {:put $m;};
it’s ony example but does,t works too.
Works for me, make sure you are using latest version. Also you can try to put ip address in quotes:
:foreach m in=[/queue simple find target-address=“10.1.91.9/32”] do={:put $m;}
It’s very strange for me but don’t work;
[admin@rtr-243] /queue simple> pr
0 name=“10.1.243.10” target-addresses=10.1.243.10/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both
priority=8 queue=default-small/default-small limit-at=460000/680000 max-limit=480000/700000 total-queue=default-small
time=8h-23h59m59s,sun,mon,tue,wed,thu,fri,sat
1 name=“P.10.1.243.10” target-addresses=10.1.243.10/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both
priority=8 queue=default-small/default-small limit-at=760000/980000 max-limit=780000/1000000 total-queue=default-small
time=0s-8h,sun,mon,tue,wed,thu,fri,sat
2 name=“10.1.243.11” target-addresses=10.1.243.11/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both
3 name=“P.10.1.243.11” target-addresses=10.1.243.11/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both
[admin@rtr-243] /queue simple> :foreach m in=[/queue simple find target-address=“10.1.243.11/32”] do {:put $m;};
I have version of 3.6, 3.7 and try everything with target-address: 10.1.243.11/32,“10.1.243.11/32”,“10.1.243.11”,10.1.243.11 without effect.
It’s work on previos version perfectly.
