Problem with script for no-ip.info after update to 6.12
Thanks a lot, trying and trying for hours but it finally works! :slight_smile:
Hello - I tried mgx’s script and found that there was a problem if you were trying to update the IP for more than one hostname at a time using this script.
I eventually traced the problem to line #51, where the script gets the previous IP for the hostname. This part of the script does not support multiple hostnames but the actual IP updation process does. As a quick workaround, I added another variable which is for a single hostname only and did the previous IP check using this new variable.
I also made one more change which is to use a HTTPS connection when calling the no-ip page, which is a better option when using HTTP basic auth.
This is tested to be working on ROS 6.30.1
#No-IP automatic Dynamic DNS update for RouterOS v6.x
#--------------- Change Values in this section to match your setup ------------------
# No-IP User account info
:local noipuser "YOUR_LOGIN_TO_NO_IP"
:local noippass "YOUR_PASSWORD_TO NO_IP"
# Workaround - find IP of a single dynamic host for IP prior to update
# Only enter a single hostname for this variable
:local previphost "YOUR_HOST.no-ip.org"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "YOUR_HOST.no-ip.org,YOUR_HOST.no-ip.com"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "YOUR_WAN_INTERFACE_NAME_f.e_port2_public"
# No more changes need
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="dyndns.checkip.html"
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info "Update NO-IP.com: currentIP = $currentIP"
# Get the current IP on the interface
#   :local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
# Strip the net mask off the IP address
#   :for i from=( [:len $currentIP] - 1) to=0 do={
#       :if ( [:pick $currentIP $i] = "/") do={
#           :set currentIP [:pick $currentIP 0 $i]
# Get your previous IP address
   :set previousIP [:resolve $previphost]
   :if ($currentIP != $previousIP) do={
       :log info "No-IP: Current IP $currentIP is not equal to previous IP $previousIP, update needed"
       :set previousIP $currentIP
# The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
       :local url "https://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
       :local noiphostarray
       :set noiphostarray [:toarray $noiphost]
       :foreach host in=$noiphostarray do={
           :log info "No-IP: Sending update for $host"
           /tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=https keep-result=no;
           :log info "No-IP: Host $host updated on No-IP with IP $currentIP"
   }  else={
       :log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed"
} else={
   :log info "No-IP: $inetinterface is not currently running, so therefore will not update."
Unfortunately none of the above seems to be working on 6.42.3.
Has anyone managed to resolve the problem?
Thank you in advance.
thank u
work on 6.45.3
note : don’t have “-” interface name.
# No-IP automatic Dynamic DNS update
:local noipuser "*******"
:local noippass "******"
:local noiphost "irvpnmeshki.ddns.net"
:local inetinterface "pppoe"
:global previousIP
       :log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
       :local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
           /tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http dst-path=("no_ip_ddns_update_" . $host . ".txt")
   }  else={
} else={
Edit you post, select your script and click code button </> to get a better formatting on your post.
So it become like this :)
