My script for dynamic IP update for no-ip.info behave weird after update to 6.12 from 5.20. At first I have problem to update IP since he was updating old IP, and now he change IP variable to new IP, but he is updating it every time when script run instead to write to log that no update is needed.
Here is the script:
# No-IP automatic Dynamic DNS update
#--------------- Change Values in this section to match your setup ------------------
# No-IP User account info
:local noipuser "MY-EMAIL@gmail.com"
:local noippass "MY-PASSWORD"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "MY-HOSTNAME.noip.me"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "ADSL" #pppoe interface for ISP
# No more changes need
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
# Get the current IP on the interface
:local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
# Strip the net mask off the IP address
:for i from=( [:len $currentIP] - 1) to=0 do={
:if ( [:pick $currentIP $i] = "/") do={
:set currentIP [:pick $currentIP 0 $i]
:if ($currentIP != $previousIP) do={
:log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
:set previousIP $currentIP
# The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
:local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
:local noiphostarray
:set noiphostarray [:toarray $noiphost]
:foreach host in=$noiphostarray do={
:log info "No-IP: Sending update for $host"
/tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http dst-path=("no_ip_ddns_update_" . $host . ".txt")
:log info "No-IP: Host $host updated on No-IP with IP $currentIP"
} else={
:log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed"
} else={
:log info "No-IP: $inetinterface is not currently running, so therefore will not update."
I only figured out that he is not creating global variable previousIP and if I create it manually he is not updating value…
If you want paste this on terminal, put \ before ?
But this script is intended to be used on scheduled script or terminal?
Obviously on script, then leave ? alone and do not escape anything, 6.x fetch not support escaped characters.
I fix all errors I have noticed, for example declaring LOCAL variables inside cycles, at the end of the cycle the local variables declared INSIDE the cycle are deleted…
:local noipuser value="MY-EMAIL@gmail.com";
:local noippass value="MY-PASSWORD";
:local noiphost value="MY-HOSTNAME.noip.me";
:local inetinterface value="ADSL";
:local currentIP value="0.0.0.0/0";
:local url value="http://dynupdate.no-ip.com/nic/update?myip=";
:if ([/interface get $inetinterface value-name=running] = true) do={
:set $currentIP value=[/ip address get [find where interface=$inetinterface] address];
:for i from=([:len $currentIP] - 1) to=0 do={
:if ([:pick $currentIP $i] = "/") do={
:set $currentIP value=[:pick $currentIP 0 $i];
:log info message=("No-IP: Current IP ".$currentIP." is not equal to previous IP, update needed");
:set $previousIP value=$currentIP;
:log info message=("No-IP: Sending update for ".$noiphost);
/tool fetch url=($url.$currentIP."&hostname=".$noiphost) user=$noipuser password=$noippass mode=http dst-path=("no_ip_ddns_update_".$noiphost.".txt");
:log info message=("No-IP: Host ".$noiphost." updated on No-IP with IP ".$currentIP);
} else={
:log info message=("No-IP: Previous IP ".$previousIP." is equal to current IP, no update needed");
} else={
:log info message=("No-IP: ".$inetinterface." is not currently running, so therefore will not update.");
I don’t want to start new topic for this offtopic 'cause it’s 6.12 update related and guess someone can give me quick info:
I was changing queues limitations and I notice that my Max Limit for Target Upload (and column Upload Max Limit) is actually my download limit. Same thing for Target Download which is my upload limit.
Is that a 6.12 change/bug or I just forgot that it was the same in 5.20 version???
I made small corrections in no-ip update script and it’s working on RouterOS v6.13.
The changes are:
Get value for previous IP address
# Get your previous IP address
:set previousIP [:resolve $noiphost]
Remove creation of no_ip_ddns_update_<no-ip_host>.txt from fetch command with option keep-result=no
Entire code of script:
# No-IP automatic Dynamic DNS update for RouterOS v6.x
:local noipuser "your_no-ip_user"
:local noippass "your_no-ip_pass"
:local noiphost "hostname.no-ip.net"
:local inetinterface "your_external_interface"
:global previousIP
:log info "No-IP: Current IP $currentIP is not equal to previous IP $previousIP, update needed"
/tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http keep-result=no;
} else={
} else={
I Have a RB951G whith routerOS 6.13 - This script doesn’t work, i create this file “no-ip_ddns_update” and execute this file with scheduler, but not work.
i attach the script:
:local noipuser "xxxxxx" <MY USER ID>
:local noippass "xxxxxx" <MY PASSWORD>
:local noiphost "xxxxxx.noip.me" <MY HOSTNAME>
:local inetinterface "pppoe-out1" <MY NAME OF INTERFACE>
:global previousIP
} else={
} else={
Compiled the script with my: email login, password, host and copy the code into /system script http://pichost.me/1839367/
but when created “if I ever created good”, how do I launch this script every 10 or 5 minute used with scheduler???
Sorry but for me it’s first time to work with script.
Advice is welcome
The script in my previous post is working on a same hardware as yours (951G) and on a same OS version (RouterOS 6.13).
I saw that you have option disabled=no in your job scheduler, which means that this job will not be executed. You can use scheduler entry from Wiki page:
Hi Guys,
i Resolved the problem with the modify at the script, thanks at the my friend’s forum “rodolfo”.
Post the working script to insert with scheduler at 5 minute MODIFY ONLY CAPS:
:local noipuser value="INSERT MAIL";
:local noippass value="INSERT PASSWORD";
:local noiphost value="INSERT HOSTNAME";
:local inetinterface value="NAME OF ADSL INTERFACE FOR MY CONNECTION IS PPPOE-OUT1";
:if ([/interface get NAME OF ADSL INTERFACE value-name=running] = true) do={
:set $currentIP value=[/ip address get [find where interface=NAME OF ADSL INTERFACE] address];
} else={
} else={
:log info message=("No-IP: ".NAME OF ADSL INTERFACE." is not currently running, so therefore will not update.");
And this is the scheduler script to launch automatically on reboot:
no of your scripts has worked for me (as I am behind 2nd NAT), so working modification
#No-IP automatic Dynamic DNS update for RouterOS v6.x
:local noipuser "YOUR_LOGIN_TO_NO_IP"
:local noippass "YOUR_PASSWORD_TO NO_IP"
:local noiphost "YOUR_HOST.no-ip.org"
:local inetinterface "YOUR_WAN_INTERFACE_NAME_f.e_port2_public"
:global previousIP
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info "Update NO-IP.com: currentIP = $currentIP"
# :local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
# :for i from=( [:len $currentIP] - 1) to=0 do={
# :if ( [:pick $currentIP $i] = "/") do={
# :set currentIP [:pick $currentIP 0 $i]
} else={
} else={
I think writing file to flash every script run can destroy flash memory very fast.
That my modification of script working with NAT. It can’t check prevous ip, update only every run. Writes to flash not needed.
:global previousIP
:local url "http://dynupdate.no-ip.com/nic/update\3F"
} else={
