Problem with VLANs and Bridge
Late to the game but I see you need rescuing LOL
Assumes the management subnet is being sent to the MT as vlan and I am using vlan11.
Ether8 is not the managment subnet is the same subnet so taking this as an offbridge safe place to do the config etc.
DCHP client should be disabled!!
add name=BR1 vlan-filtering=yes
set [ find default-name=ether7 ] comment=TRUNK
set [ find default-name=ether8 ] comment=OffBridge8
/interface vlan
add interface=BR1 name=vlanMGMT vlan-id=11
add name=TRUSTED
/interface list-member
add interface=vlanMGMT list=TRUSTED
add interface=OffBridge8 list=TRUSTED
/port
set 0 name=serial0
set 1 name=serial1
add bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged interface=\
    ether1 pvid=10
    ether2 pvid=10
    ether3 pvid=20
    ether4 pvid=20
    ether5 pvid=30
    ether6 pvid=30
add bridge=BR1  ingress-filtering=yes frame-types=admit-only-vlan-tagged interface=ether7  comment="trunk from Nonsense"
set discover-interface-list=TRUSTED
/interface bridge vlan
add  bridge=BR1 tagged=ether7,BR1  vlan-ids=11
add bridge=BR1 tagged=ether7  untagged=ether1,ether2 vlan-ids=10
add bridge=BR1 tagged=ether7  untagged=ether3,ether4 vlan-ids=20
add bridge=BR1 tagged=ether7  untagged=ether5,ether6 vlan-ids=30
/ip dhcp-client
add interface=ether1 disable=yes
add address=192.168.11.XX/24  interface=vlanMGMT  network=192.168.11.0  { static IP from opensense }
add address=192.168.88.1/30  interface=OffBridge8  network=192.168.88.0   { use 192.168.88.2 for IPV4 settings to login with laptop }
/system identity
set name=MK-Pnet
/system note
set show-at-login=no
/system package update
set channel=development
set server=192.168.11.1
dst-address=0.0.0.0/0 gateway=192.168.11.1
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/system ntp client
set enabled=yes mode=manycast
/system ntp client servers
add address=192.168.11.1
