Problema VPN MacOs
Buen dia para todos.
Tengo un routerboard 750, con un problema:
Las conexiones PPTP para windows, funcionan perfectamente; En MacOs tengo dos equipos conectados sin problema bajo una IP Fija y conexion L2TP, pero cuando intento crear una nueva conexion en otro Mac, ya no me permite conectar, ni siquiera desconectando los anteriories.
Tengo ping a la direccion IP fija, desde cualquier equipo (con windows o mac) pero la vpn bajo mac ya no conecta. ayuda por favor.
Mil gracias a todos
Bienvenido al Foro, normalmente se utiliza el idioma ingles
Welcome to the Forum, English is normally used
Good day to everyone. I have a routerboard 750, with a problem: The PPTP connections for Windows work perfectly; I have two Macs connected without issue under a fixed IP and L2TP connection, but when I try to create a new connection on another Mac, it no longer allows me to connect, not even by disconnecting the previous ones. I can ping the fixed IP address from any device (whether Windows or Mac), but the VPN on Mac no longer connects. Help please. A thousand thanks to everyone.
If the Macs are setup the same and two work while one does not, I would probably start turning on some logging on the routerboard to see what the router reports. There should be a clue there. If not, then you would need to look on the logs on the Mac side and investigate further for answers.
I don’t usually have much trouble with Macs and VPN connection to Mikrotik, so if it were me, I would probably double and triple check configuration to be sure I hadn’t made a silly typo somewhere or something because I have been known to do that at times. :slight_smile:
All the OS makers are trying to get rid of l2tp and even more so pptp.
If you could possibly use wireguard, you would be a lot better off.
Need a preferably recent V7 routeros on your RB750 if it is a hex it should be fine,
if something older/less capable, you might get it working, but probably worth getting something newer.
Debugging such things usually starts with logging. What do you see in your router logs?
Moreover:
PPTP is long time outdated and deprecated.
So is L2TP.
The best solution is IKEv2 as both Mac and Windows have built-in clients.
