Hi all,
This weekend I was trying for the first time to get IPv6 working. I got an HE tunnel with the usual /64 and a /48 for my other networks.
All seems fine and not as horrifying as first looked upon ![]()
Then I ran in to troubleā¦
I must have done something wrong but I can not figure out whatā¦
The problem is that I can not assign an IPv6 address to a bridge interface. I have a static mac address on the interfaces but still no luck.
I did try thisā¦
/interface bridge add name=lobridge auto-mac=no admin-mac=01:00:00:00:01:00
# loopback address
/ipv6 address add address=2001:abc:defg:3::1/64 advertise=no interface=lobridge
And it worked⦠But using the same admin-mac on the ārealā bridge did not work ![]()
As an troubleshooting effort I connected a computer to local interface āInternalā and it worked instantly. So it seems to be only bridge interfaces affected by this.
I have also rebooted several times. Still no luck.
Here is my current setup. As you can see in the last code section bridge1 and bridge2 is unreachable⦠Any ideas why and how I can fix it?
[admin@foo.bar] > interface print detail
0 name="Dmz" type="ether" mtu=1500 l2mtu=1600 max-l2mtu=9116
1 R name="External" type="ether" mtu=1500 l2mtu=1600 max-l2mtu=9500
2 R name="Internal" type="ether" mtu=1500 l2mtu=1600 max-l2mtu=9500
3 ;;; 5Ghz-A-N
name="wlan1" type="wlan" mtu=1500 l2mtu=2290
4 R ;;; xxxxx
name="xxxx" type="pptp-out" mtu=1460
5 R ;;; Wifi-1
name="bridge1" type="bridge" mtu=1500 l2mtu=2290
6 R ;;; Wifi-2
name="bridge2" type="bridge" mtu=1500 l2mtu=2290
7 ;;; 2Ghz-B-G-N
name="wlan2" type="wlan" mtu=1500 l2mtu=2290
8 R ;;; W-1
name="wlan3" type="wlan" mtu=1500 l2mtu=2290
9 ;;; W-2
name="wlan4" type="wlan" mtu=1500 l2mtu=2290
10 R ;;; W-1
name="wlan5" type="wlan" mtu=1500 l2mtu=2290
11 R ;;; W-2
name="wlan6" type="wlan" mtu=1500 l2mtu=2290
12 ;;; Home
name="pptp-in1" type="pptp-in"
13 R ;;; HE IPv6
name="sit1" type="sit" mtu=1280
[admin@foo.bar] > interface bridge print detail
0 R ;;; Wifi-1
name="bridge1" mtu=1500 l2mtu=2290 arp=reply-only mac-address=02:0C:42:3A:E9:49 protocol-mode=rstp priority=0x8000 auto-mac=no
admin-mac=02:0C:42:3A:E9:49 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R ;;; Wifi-2
name="bridge2" mtu=1500 l2mtu=2290 arp=reply-only mac-address=02:0C:42:3A:E8:64 protocol-mode=rstp priority=0x8000 auto-mac=no
admin-mac=02:0C:42:3A:E8:64 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
[admin@foo.bar] > interface bridge port print detail
Flags: X - disabled, I - inactive, D - dynamic
0 interface=wlan5 bridge=bridge1 priority=0x80 path-cost=10 edge=auto point-to-point=auto external-fdb=auto horizon=none
1 I interface=wlan4 bridge=bridge2 priority=0x80 path-cost=10 edge=auto point-to-point=auto external-fdb=auto horizon=none
2 interface=wlan3 bridge=bridge1 priority=0x80 path-cost=10 edge=auto point-to-point=auto external-fdb=auto horizon=none
3 interface=wlan6 bridge=bridge2 priority=0x80 path-cost=10 edge=auto point-to-point=auto external-fdb=auto horizon=none
[admin@foo.bar] > ipv6 address print detail
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
0 G address=2001:abc:xy:opq::2/64 interface=sit1 actual-interface=sit1 eui-64=no advertise=no
1 G address=2001:abc:defg:1::1/64 interface=Internal actual-interface=Internal eui-64=no advertise=yes
2 G address=2001:abc:defg:2::1/64 interface=Dmz actual-interface=Dmz eui-64=no advertise=no
3 G address=2001:abc:defg:3::1/64 interface=bridge1 actual-interface=bridge1 eui-64=no advertise=yes
4 G address=2001:abc:defg:4::1/64 interface=bridge2 actual-interface=bridge2 eui-64=no advertise=yes
5 DL address=fe80::53e3:ab22/128 interface=sit1 actual-interface=sit1 eui-64=no advertise=no
6 DL address=fe80::20c:42ff:fe25:e5b2/64 interface=External actual-interface=External eui-64=no advertise=no
7 DL address=fe80::20c:42ff:fe73:3247/64 interface=Internal actual-interface=Internal eui-64=no advertise=no
[admin@foo.bar] > ipv6 route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
0 A S dst-address=2000::/3 gateway=2001:abc:xy:opq::1 gateway-status=2001:abc:xy:opq::1 reachable sit1 distance=1 scope=30 target-scope=10
1 ADC dst-address=2001:abc:xy:opq::/64 gateway=sit1 gateway-status=sit1 reachable distance=0 scope=10
2 ADC dst-address=2001:abc:defg:1::/64 gateway=Internal gateway-status=Internal reachable distance=0 scope=10
3 ADC dst-address=2001:abc:defg:2::/64 gateway=Dmz gateway-status=Dmz unreachable distance=0 scope=200
4 ADC dst-address=2001:abc:defg:3::/64 gateway=bridge1 gateway-status=bridge1 unreachable distance=0 scope=10
5 ADC dst-address=2001:abc:defg:4::/64 gateway=bridge2 gateway-status=bridge2 unreachable distance=0 scope=10
Updateā¦
I reviewed the log files this evening and saw thisā¦
21:43:37 radvd,debug skip Router Advertisement sending on bridge1: no link local address
21:45:51 radvd,debug skip Router Advertisement sending on bridge2: no link local address
Best regards,
/Frank
