How you can see the maximum upload is 32kbps and the maximum download is 200kbps, but the client can do downloads approximately 400kbps and the upload is always around of 50kbps constantly.
Has somebody any idea of why this happen?
PS: The type of default queue is bfifo now but I tested pfifo and red types.
I’m not sure, but I think that with this simples queue you can’t be able to control de upload bandwidth because you specified the destination address instead of target address.
I’m with problems when I use pfifo or bfifo. I try to use red today and I think that the problem was solved with this type of queue. But I want to know why can I use pfifo and bfifo?
too little information. Im using connection limit, p2p blocking and queue tree with services packet marking. All working fine. Im remember some problem with overloaded simple queues with old 2.8.26? mt version… Mabe its problem with lack of parameters in your queues? Did you try use burst limit parameters? (i mean max, threshold and time)
Im not sure. Im using, and discovering MT from 1,5 year. Using simple queues as you saw my example almost from begin (burst limit = max limit) Its working. Maybe burst limits are not required. I dont want try change this. Too many users in my network (about 600) and it will be too risky. Hope someone else with bigger MT knowledge can help you more.
I’ll try to change, but how I said: The problem don’t occours with all my users just with some users and I’ve a lot of users to and change all simple queues will do a lot of work.
Maybe not all of your users using the same communication methods (as flashget download, p2p programs, p2m etc.) and it looks as queues works for almos all except few peoples.
Change one bad working queue and watch what will be isnt not much work i think so.
(about changing lot of queues, im doing it too sometimes. I using script with “for” mt command)
