I have a hex S since a few years, connected to a CSS322. Back then, all tutorials were not using any bridge. Now I want to use a Bridge, however, if I activate VLAN Filtering, my network collapses.
The network looks like that:
This is my configuration:
export hide-sensitive
# jun/22/2021 13:38:39 by RouterOS 6.48.3
# software id = XE0V-A40Q
# model = RB760iGS
# serial number = A815099AF64D
add name=bridge1
set [ find default-name=ether2 ] name="ether2(WLAN)"
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add interface=bridge1 name=vlan1 vlan-id=1
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan20 vlan-id=20
add interface=bridge1 name=vlan30 vlan-id=30
add interface=bridge1 name=vlan50 vlan-id=50
add name=WAN
add name=LAN
add name=VLAN
add name=BASE
add name=VLANblock
add name=vlan1 ranges=192.168.0.20-192.168.0.40
add name=vlan20 ranges=192.168.20.2-192.168.20.254
add name=vlan10 ranges=192.168.10.2-192.168.10.254
add name=DMZ ranges=192.168.100.2-192.168.100.254
add name=vlan30 ranges=192.168.30.2-192.168.30.254
add name=vlan50 ranges=192.168.50.3-192.168.50.100
add name=" pool-vpn" ranges=192.168.123.100-192.168.123.199
add address-pool=vlan1 disabled=no interface=vlan1 lease-script=\
dhcp-lease-script lease-time=2h name=vlan1
add address-pool=vlan20 disabled=no interface=vlan20 lease-script=\
dhcp-lease-script name=vlan20
add address-pool=DMZ disabled=no interface=ether4 name=dhcp3
add address-pool=vlan10 disabled=no interface=vlan10 lease-script=\
dhcp-lease-script name=vlan10
add address-pool=vlan30 disabled=no interface=vlan30 lease-script=\
dhcp-lease-script lease-time=4d4h10m name=vlan30
add address-pool=vlan1 interface="ether2(WLAN)" name=WLAN
add address-pool=vlan50 disabled=no interface=vlan50 lease-script=\
dhcp-lease-script name=vlan50
/port
set 0 name=serial0
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
ord,web,sniff,sensitive,api,romon,dude,tikapp"
/dude
set enabled=yes
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=yes interface=ether5
ingress-filtering=yes interface=ether3
add bridge=bridge1 interface="ether2(WLAN)"
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether5,ether3 vlan-ids=10
add bridge=bridge1 tagged=bridge1,ether5,ether3 vlan-ids=20
add bridge=bridge1 tagged=bridge1,ether5,ether3 vlan-ids=30
add bridge=bridge1 tagged=bridge1,ether5,ether3 vlan-ids=50
add bridge=bridge1 tagged=bridge1 untagged=ether3,ether5 vlan-ids=1
/interface detect-internet
set detect-interface-list=all
add interface=ether1 list=WAN
add interface=ether5 list=LAN
add interface=vlan10 list=VLAN
add interface=vlan20 list=VLAN
add interface=vlan30 list=VLAN
add interface=vlan50 list=VLAN
add interface=vlan1 list=BASE
/interface ovpn-server server
set auth=sha1 certificate="VPN Server" cipher=aes256 default-profile=vpn \
enabled=yes require-client-certificate=yes
add address=192.168.0.1/24 interface=ether5 network=192.168.0.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
add address=192.168.100.1/24 interface=ether4 network=192.168.100.0
add address=xx.xx.xx.xx2/30 interface=ether1 network=xx.xx.xx.xx0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
add address=192.168.50.1/24 interface=vlan50 network=192.168.50.0
add address=192.168.0.1/24 disabled=yes interface=vlan1 network=192.168.0.0
/ip dhcp-server lease
add address=192.168.0.136 allow-dual-stack-queue=no disabled=yes mac-address=\
00:02:C9:4E:89:26 server=vlan1
add address=192.168.0.113 allow-dual-stack-queue=no disabled=yes mac-address=\
F2:E7:52:EB:6E:9B server=vlan1
add address=192.168.0.26 client-id=1:0:26:ab:6c:6:27 disabled=yes mac-address=\
00:26:AB:6C:06:27 server=vlan1
add address=192.168.0.33 client-id=1:0:2:c9:51:77:dc disabled=yes mac-address=\
00:02:C9:51:77:DC server=vlan1
add address=192.168.50.100 client-id=1:2c:f0:5d:3b:db:d3 disabled=yes \
mac-address=2C:F0:5D:3B:DB:D3 server=WLAN
add address=192.168.0.0/24 dns-server=192.168.0.1 domain=home.lab gateway=\
192.168.0.1 netmask=24
add address=192.168.10.0/24 dns-server=192.168.0.1 domain=service.lab gateway=\
192.168.10.1
add address=192.168.20.0/24 dns-server=192.168.0.1 domain=vlan20.lab gateway=\
192.168.20.1 netmask=24
add address=192.168.30.0/24 dns-server=192.168.30.1 domain=vlan30.lab gateway=\
192.168.30.1
add address=192.168.50.0/24 dns-server=192.168.0.1 domain=private.lab gateway=\
192.168.50.1
add address=192.168.100.0/24 dns-server=192.168.100.1 domain=dmz.lab gateway=\
192.168.100.1 netmask=24
set allow-remote-requests=yes servers=192.168.0.3,192.168.10.13
/ip dns static
add address=192.168.100.110 name=mydomain2.de
add address=192.168.100.110 name=mydomain1.de
add address=192.168.100.110 name=mydomain3.de
add address=192.168.0.131 name=pve.home.lab
add address=192.168.0.2 name=r620.home.lab
add address=192.168.0.113 name=nanopineo.home.lab
add address=192.168.0.128 name=grafana.home.lab
add address=192.168.0.136 name=fileserver.home.lab
add address=192.168.0.10 name=pve2.home.lab
add address=192.168.10.18 name=bookstack.service.lab
add address=192.168.10.123 name=Guacamole.service.lab
add address=192.168.10.101 comment=#DHCP name=Heimdall.service.lab ttl=10m
add address=192.168.10.122 disabled=yes name=avideo.service.lab
add address=192.168.10.123 name=avideo1.service.lab
add address=192.168.0.21 comment=#DHCP name=GUI.home.lab ttl=2h
add address=192.168.0.22 comment=#DHCP name=GUI.home.lab ttl=2h
add address=192.168.0.32 comment=#DHCP name=openhab.home.lab ttl=2h
add address=192.168.30.254 comment=#DHCP name=debian.vlan30.lab ttl=4d4h10m
add address=192.168.0.24 comment=#DHCP name=HS110.home.lab ttl=2h
add address=192.168.0.27 comment=#DHCP name=Ryzen-Workstation.home.lab ttl=2h
add address=192.168.10.253 comment=#DHCP name=debian2.service.lab ttl=10m
add action=accept chain=input comment="Allow Established connections" \
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow VLAN" in-interface-list=BASE
add action=accept chain=input comment="Allow LAN" in-interface=bridge1
add action=accept chain=input comment="Allow ICMP" protocol=icmp
add action=accept chain=forward comment="Allow Estab & Related" \
connection-nat-state="" connection-state=established,related
add action=accept chain=forward comment="VLAN darf ins Internet" \
connection-nat-state="" connection-state=related,new in-interface-list=VLAN \
out-interface-list=WAN
"alllow inter VLAN Access for all not originated from vlan30" \
connection-state=new in-interface=!vlan30 in-interface-list=VLAN \
out-interface-list=VLAN
add action=accept chain=forward comment="Wireguard #1" dst-port=51820 protocol=\
udp
add action=accept chain=forward comment="Wireguard #2" dst-port=51821 protocol=\
udp
add action=accept chain=forward comment="Allow traffic between these subnets" \
dst-address=192.168.0.0/24 src-address=10.9.0.0/24
add action=accept chain=input comment="Allow winbox from LAN" dst-port=8291 \
in-interface-list=!WAN log=yes protocol=tcp
add action=accept chain=input dst-port=4443 protocol=tcp
add action=accept chain=input dst-port=88 protocol=tcp
add action=jump chain=forward jump-target=tcp protocol=tcp
add action=jump chain=forward jump-target=udp protocol=udp
add action=jump chain=forward jump-target=icmp protocol=icmp
add action=accept chain=input dst-port=161 in-interface=bridge1 protocol=udp
add action=accept chain=input dst-port=53 in-interface-list=!WAN protocol=tcp
add action=accept chain=input dst-port=53 in-interface-list=!WAN protocol=udp
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=\
udp
add action=accept chain=forward comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE (Wlan Telefonie)" \
connection-type=sip dst-port=500 log=yes protocol=udp
add action=accept chain=forward comment="allow IKE (Wlan Telefonie)" dst-port=\
500 protocol=udp
"Allow traffic between Workstation and Webserver" dst-address=192.168.0.127 \
dst-port=445 protocol=tcp src-address=192.168.100.156
"Allow traffic between Workstation and Webserver" dst-address=\
192.168.100.110 dst-port=443,80 protocol=tcp src-address=192.168.0.0/24
add action=drop chain=forward comment="drop invalid connections" \
connection-state=invalid protocol=tcp
add action=drop chain=forward comment="Block traffic between these subnets" \
dst-address=192.168.100.0/24 src-address=192.168.0.0/24
dst-address=192.168.0.0/24 src-address=192.168.100.0/24
dst-address=192.168.20.0/24 src-address=192.168.100.0/24
dst-address=192.168.10.0/24 src-address=192.168.100.0/24
add action=drop chain=input comment="Block Russian, Chinese and Vietnam IPs" \
log=yes src-address-list=CountryIPBlocks
add action=drop chain=input comment="drop winbox from wan" dst-port=8291 \
in-interface-list=WAN log=yes protocol=tcp
add action=drop chain=input dst-port=53 in-interface-list=WAN protocol=tcp
add action=drop chain=input dst-port=53 in-interface-list=WAN protocol=udp
add action=drop chain=input comment="Block everything else"
add action=drop chain=forward connection-nat-state=!dstnat in-interface-list=\
WAN
add action=drop chain=forward comment="Block everything else" disabled=yes
add action=accept chain=srcnat dst-address-type=local
add action=dst-nat chain=dstnat comment="HTTPS an reverse proxy" dst-address=\
xx.xx.xx.xx2 dst-port=80,443 protocol=tcp to-addresses=192.168.100.110
add action=dst-nat chain=dstnat dst-address=xx.xx.xx.xx2 dst-port=8444 \
in-interface=ether1 protocol=tcp to-addresses=192.168.100.110 to-ports=443
add action=dst-nat chain=dstnat dst-address=xx.xx.xx.xx2 dst-port=1194 \
in-interface=ether1 log=yes protocol=udp to-addresses=192.168.0.113 \
to-ports=1194
add action=dst-nat chain=dstnat comment="TURN Server Nextcloud mydomain2" \
dst-address=xx.xx.xx.xx2 dst-port=3478 log=yes protocol=tcp to-addresses=\
192.168.100.156 to-ports=3478
dst-address=xx.xx.xx.xx2 dst-port=3479 log=yes protocol=tcp to-addresses=\
192.168.100.156 to-ports=3479
dst-address=xx.xx.xx.xx2 dst-port=3478 protocol=udp to-addresses=\
dst-address=xx.xx.xx.xx2 dst-port=3479 log=yes protocol=udp to-addresses=\
add action=dst-nat chain=dstnat comment="TURN Server cloud.mydomain2" \
dst-address=xx.xx.xx.xx2 dst-port=5349 log=yes protocol=tcp to-addresses=\
192.168.100.138 to-ports=5349
dst-address=xx.xx.xx.xx2 dst-port=5350 log=yes protocol=tcp to-addresses=\
192.168.100.138 to-ports=5350
dst-address=xx.xx.xx.xx2 dst-port=5349 log=yes protocol=udp to-addresses=\
dst-address=xx.xx.xx.xx2 dst-port=5350 in-interface=ether1 log=yes \
protocol=udp to-addresses=192.168.100.138 to-ports=5350
add action=dst-nat chain=dstnat dst-port=51820 in-interface=ether1 protocol=udp \
to-addresses=192.168.0.217 to-ports=51820
add action=dst-nat chain=dstnat dst-port=51821 in-interface=ether1 protocol=udp \
to-addresses=192.168.0.218 to-ports=51821
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
/ip ipsec policy
set 0 disabled=yes
add distance=1 gateway=xx.xx.xx.xx1
/ip service
set telnet address=192.168.0.0/24 disabled=yes
set ftp address=192.168.0.0/24 disabled=yes
set www address=192.168.0.0/24 port=88
set ssh address=192.168.0.0/24 disabled=yes
set www-ssl address=192.168.0.0/24 disabled=no port=4443
set api address=192.168.0.0/24 disabled=yes
set winbox address=192.168.0.0/24
set api-ssl address=192.168.0.0/24 disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set allow-disable-external-interface=yes
/ip upnp interfaces
add type=internal
add interface=ether1 type=external
/ppp secret
add name=AWI profile=vpn service=ovpn
/snmp
set enabled=yes trap-generators="" trap-version=2
/system clock
/system script
add dont-require-permissions=no name=dhcp-lease-script owner=user policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=" \
\_:local DHCPtag\r\
\n :set DHCPtag \"#DHCP\"\r\
\n :if ( [ :len \$leaseActIP ] <= 0 ) do={ :error \"empty lease address\"\
\_}\r\
\n :if ( \$leaseBound = 1 ) do={\r\
\n :local ttl\r\
\n :local domain\r\
\n :local hostname\r\
\n :local dnsname\r\
\n :local fqdn\r\
\n :local leaseId\r\
\n :local comment\r\
\n :local devicename\r\
\n :local convert ({})\r\
\n :local validChars \"abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRST\
UVWXYZ01234567890-\"\r\
\n /ip dhcp-server\r\
\n :set ttl [ get [ find name=\$leaseServerName ] lease-time ]\r\
\n network \r\
\n :set domain [ get [ find \$leaseActIP in address ] domain ]\r\
\n .. lease\r\
\n :set leaseId [ find address=\$leaseActIP ]\r\
\n # Check for multiple active leases for the same IP address. It's w\
eird and it shouldn't be, but just in case.\r\
\n :if ( [ :len \$leaseId ] != 1) do={\r\
\n :log info \"DHCP2DNS: not registering domain name for address \
\$leaseActIP because of multiple active leases for \$leaseActIP\"\r\
\n :error \"multiple active leases for \$leaseActIP\"\r\
\n }\r\
\n :set hostname [ get \$leaseId host-name ]\r\
\n :set comment [ get \$leaseId comment ]\r\
\n /\r\
\n # Namen f\FCr Ger\E4t ermittlen\r\
\n :set devicename \$comment\r\
\n :if ( [ :len \$devicename ] <= 0 ) do={\r\
\n :set devicename \$hostname\r\
\n }\r\
\n # Ger\E4tenamen auf ung\FCltige Zeichen pr\FCfen\r\
\n :for validCharsIndex from=0 to=([:len \$validChars] - 1) do={\r\
\n :local validChar [:pick \$validChars \$validCharsIndex]\r\
\n :set (\$convert->(\$validChar)) (\$validChar)\r\
\n }\r\
\n :set (\$convert->(\"_\")) (\"-\")\r\
\n :set (\$convert->(\" \")) (\"-\")\r\
\n :for i from=0 to=([:len \$devicename] - 1) do={\r\
\n :local char [:pick \$devicename \$i]\r\
\n :local converted (\$convert->\"\$char\")\r\
\n :local convertedType [:typeof \$converted]\r\
\n :if (\$convertedType = \"str\") do={\r\
\n :set \$char \$converted\r\
\n } else={\r\
\n :set \$char \"\"\r\
\n }\r\
\n :set dnsname (\$dnsname.\$char)\r\
\n }\r\
\n # FQDN festlegen\r\
\n :if ( [ :len \$dnsname ] <= 0 ) do={\r\
\n :log error \"DHCP2DNS: not registering domain name for address\
\_\$leaseActIP because of empty lease host-name or comment\"\r\
\n :error \"empty lease host-name or comment\"\r\
\n }\r\
\n :if ( [ :len \$domain ] <= 0 ) do={\r\
\_\$leaseActIP because of empty network domain name\"\r\
\n :error \"empty network domain name\"\r\
\n }\r\
\n :set fqdn \"\$dnsname.\$domain\"\r\
\n /ip dns static\r\
\n :if ( [ :len [ find name=\$fqdn and address=\$leaseActIP and disab\
led=no ] ] = 0 ) do={\r\
\n :log info \"DHCP2DNS: registering static domain name \$fqdn fo\
r address \$leaseActIP with ttl \$ttl\"\r\
\n add address=\$leaseActIP name=\$fqdn ttl=\$ttl comment=\$DHCPt\
ag disabled=no\r\
\n } else={\r\
\n :log error \"DHCP2DNS: not registering domain name \$fqdn for \
address \$leaseActIP because of existing active static DNS entry with this n\
ame or address\"\r\
\n }\r\
\n /\r\
\n } else={\r\
\n :local dnsDhcpId\r\
\n :set dnsDhcpId [ find address=\$leaseActIP and comment=\$DHCPtag ]\
\r\
\n :if ( [ :len \$dnsDhcpId ] > 0 ) do={\r\
\n :log info \"DHCP2DNS: removing static domain name(s) for addre\
ss \$leaseActIP\"\r\
\n remove \$dnsDhcpId\r\
\n }\r\
\n /\r\
\n }"
/tool bandwidth-server
set enabled=no
/tool graphing interface
add interface="ether2(WLAN)"
add interface=ether3
add interface=ether4
/tool mac-server ping
set enabled=no
With this configuration, everything is working. But VLAN Filtering over the Bridge is deactivated. In order to activate it, I have to change these:
- activate VLAN Filtering on the Bridge
- deactivate this: add address=192.168.0.1/24 interface=ether5 network=192.168.0.0 and activate this: add address=192.168.0.1/24 disabled=yes interface=vlan1 network=192.168.0.0
With this I have internet connection on VLAN 1, but not on any other VLAN. And I can’t connect to any other VLAN machine from VLAN1.
Further, if I activate this: add action=drop chain=forward comment=“Block everything else” disabled=yes then I will loose any internet connection.
What is wrong?
