hi
i am a begginer and know nothing about mikrotik
i know only login
pasword
and that s all
now i have big problems in internet connections i am working all the time and in one moment internet connection get lost.my IT can t chose this thing i can t too.can u please tell me what is the problem maybe mtu or something like this.i have mtu 1480.what problem may i have.
my IT has another router home can he acces my router from his home and change the mac adress and username password.and in the end i want to know how can i make full acces router coz i can login but i have no access in everything in my router please help.
my e mail fation_zyka2484@hotmail.com coz i don t know how did i come here and don t even know to come here again.
thanks a lot
i am still waiting your answers
thanks again
Please make it clear…look like everything is Mess-up
i have an account and an mac address from my isp.
i login and put my account and the connection established.
when i navigate on internet the connection get lost.
and i have 3 minutes of established connection and 1 minute of non internet connection.
may the problem is mikrotik
may the problem is proxim the antena
maybe the problem is… don t knowu can tell me.
bye
It is not likely that your ISP will have given you a mac address. A mac address is a unique and fixed identifier of certain equipment inside the wireless equipment you bought or were given and which is necessary for the proper working of the system. They should not be used, altered or interfered with unless you know exactly what you are doing.
Your ISP will have given you an account name and a password which the system uses to connect you to the wireless network. If you use these and get a connection they are correct, and the fact that the connection you get then doesn’t work well is either a result of the system settings being set incorrectly by the isp or, as you say, poor signal strength either because you don’t have a good line-of-sight to the other end of the radio link or the antenna is pointed wrongly.
Most ISPs don’t allow their customers to access the wireless gear directly because if you don’t know what you’re doing you can cause problems both to it and to the whole network.
So in the first instance you should take these problems up with your ISP, as I assume you are paying them for the service you’re not getting from them.
