I'm still digesting this. (I'm considering including this at the top of every post as a way out when someone yells at me re-read what was previously written (
I understand that we have the commands add, set, and remove. And, that there is a risk or possibility of duplicates. I was hoping for a more straightforward way that doesn't involve working line-by-line.
Do I understand correctly that creating a bridge or interface without including in the command "mac-address=" will result in ROS creating (or assigning) a new mac address for that interface (provided "auto-mac=no" is not included in the command)?
I went ahead and went line by on the "to be pasted" config and copied/pasted into the new device where possible and used Winbox to edit existing items (like the bridge settings) and to remove items.
I think I got it, but I am confused about whether the "ether1" line in the following section should be removed (this is a wAP attached at ether1 to a hex):
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=371wAP-2ghz pvid=32
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=371wAP-5ghz pvid=32
add bridge=bridge interface=ether1
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=2point4 pvid=12
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=Guest-2g pvid=2
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=Guest-5g pvid=2
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=Ecobee pvid=12
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=371-2g pvid=12
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=371-5g pvid=12
I also don't think I need the NAT entry:
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
Here is the entire config:
# 2025-09-16 09:27:07 by RouterOS 7.18.2
# software id = ZCPR-XWMG
# model = wAPG-5HaxD2HaxD
# serial number = HJG0AMBMKVT
add admin-mac=04:F4:1C:07:8B:4D auto-mac=no comment=defconf frame-types=\
admit-only-vlan-tagged name=bridge vlan-filtering=yes
set [ find default-name=ether2 ] comment=OffBridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-n .skip-dfs-channels=all \
.width=20mhz comment=Master-2g configuration.country="United States" \
.mode=ap .ssid=371-Wap5g disabled=no name=371wAP-2ghz \
security.authentication-types=wpa2-psk .ft=yes .ft-over-ds=yes \
.passphrase=ilovedaddy1!
set [ find default-name=wifi2 ] channel.band=5ghz-ax .skip-dfs-channels=all \
.width=20/40/80mhz comment=Master-5g configuration.country=\
"United States" .mode=ap .ssid=371-Wap5g disabled=no name=371wAP-5ghz \
add comment=Ecobee configuration.mode=ap .ssid=Ecobee disabled=no \
mac-address=06:F4:1C:07:8B:4F master-interface=371wAP-2ghz name=Ecobee \
security.authentication-types=wpa2-psk .passphrase=blueberry
add comment=Guest configuration.mode=ap .ssid=Guest disabled=no mac-address=\
06:F4:1C:07:8B:50 master-interface=371wAP-2ghz name=Guest-2g \
06:F4:1C:07:8B:4E master-interface=371wAP-5ghz name=Guest-5g \
/interface vlan
add comment="Management VLAN32" interface=bridge name=vlan-mgmt vlan-id=32
/interface wifi
add comment=2point4 configuration.mode=ap .ssid=2point4 disabled=no \
mac-address=06:F4:1C:07:8B:51 master-interface=371wAP-2ghz name=2point4 \
security.authentication-types=wpa2-psk .passphrase=ilovedaddy1!
add comment=371 configuration.mode=ap .ssid=371 disabled=no mac-address=\
06:F4:1C:07:8B:52 master-interface=371wAP-2ghz name=371-2g \
06:F4:1C:07:8B:53 master-interface=371wAP-5ghz name=371-5g \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=TRUSTED
add name=Offbridge-pool ranges=192.168.55.100-192.168.55.200
add bridge=bridge comment=defconf frame-types=\
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
set discover-interface-list=TRUSTED
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge comment=MGMT tagged=bridge,ether1 untagged=\
371wAP-2ghz,371wAP-5ghz vlan-ids=32
add bridge=bridge comment=guest tagged=ether1 untagged=Guest-2g,Guest-5g \
vlan-ids=2
add bridge=bridge comment=iot tagged=ether1 untagged=2point4 vlan-ids=12
add comment=defconf disabled=yes interface=bridge list=LAN
add interface=vlan-mgmt list=TRUSTED
add interface=ether1 list=TRUSTED
add interface=ether2 list=TRUSTED
add address=192.168.55.1/24 interface=ether2 network=192.168.55.0
add address=10.37.32.3/24 interface=vlan-mgmt network=10.37.32.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address-pool=Offbridge-pool interface=ether2 name=Offbridge
set allow-remote-requests=yes servers=10.37.32.1,1.1.1.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.37.32.1 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
/system clock
set time-zone-name=America/New_York
/system identity
set name=371wAP
/system logging
add topics=wireless
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.us.pool.ntp.org
add address=1.us.pool.ntp.org
/system scheduler
add interval=1d name=export-download on-event=export-download policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2025-03-22 start-time=06:04:32
add name=systemresourcesserialize on-event=\
":delay 60\
\n/system script run systemresourcesserialize" policy=\
start-time=startup
/system script
add dont-require-permissions=yes name=export-download owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n\
\n/system\
\n:local cdate [clock get date] \
\n:local yyyy [:pick \$cdate 0 4]\
\n:local MM [:pick \$cdate 5 7]\
\n:local dd [:pick \$cdate 8 10]\
\n:local identitydate \"\$[identity get name]_\$yyyy-\$MM-\$dd\"\
\n/export show-sensitive file=\"\$identitydate\"\
\n\
\n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$[\$identitydate].\
rsc\" dst-path=\"/mikrotik-backups/\$[\$identitydate].rsc\" address=192.16\
8.2.22 port=21 user=mikrotik password=mikrotik\
\n\
\n/file remove \"\$identitydate.rsc\"\
\n\
\n# /system logging set 0 topics=info\
\n# /system logging add action=remote prefix=192.168.0.13 topics=info\
\n\
\n:log info (\"Uploaded rsc backup to 192.168.2.22 as \".\$identitydate)\
\n\
\n# /system logging set 0 topics=info,!script\
\n# /system logging add action=remote prefix=192.168.0.13 topics=info,!scr\
ipt"
add dont-require-permissions=yes name=systemresourcesserialize owner=admin \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\
\n:local identity [/system identity get name]\
\n#:log info \$identity\
\n\
\n:local resources [/system/resource/print as-value] \
\n#:log info \$identity\\n\$resources\
\n\
\n:log info [:serialize to=json [/system/resource/print as-value] option=j\
son.pretty]\
\n\
\n\
\n\
\n:log info [:serialize to=json [/ip/address/print as-value] option=json.p\
retty]\
\n\
\n\
\n\
\n\
\n\
\n:local file1 \"resources.json\"\
\n:local file2 \"ipaddress.json\"\
\n\
\n:global findresult [/file find where name=\"\$file1\"]\
\n:if ([:len \$findresult] > 0) do={\
\n :file/remove \$file1\
\n}\
\n\
\n\
\n:global findresult [/file find where name=\"\$file2\"]\
\n :file/remove \$file2\
\n}\
\n\
\n\
\n/file/add name=\$file1 contents=[:serialize to=json [/system/resource/pr\
int as-value] option=json.pretty]\
\n\
\n\
\n\
\n/file/add name=\$file2 contents=[:serialize to=json [/ip/address/print a\
\n\
\n\
\n\
\n\
\n\
\n\
\n/system\
\n\
\n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$file1\" dst-path=\
\"/mikrotik-backups/\$[\$identitydate]-systeminfo.txt\" address=192.168.2.\
\n\
\n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$file2\" dst-path=\
\"/mikrotik-backups/\$[\$identitydate]-IPinfo.txt\" address=192.168.2.22 p\
\n"
add dont-require-permissions=yes name=netwatch-5-2025 owner=admin policy=\
\n\
\n/tool netwatch\
\n:local thisBox [/system identity get name]\
\n:local lhost [:toip \$host]\
\n:local lstatus \$status\
\n:local llosspercent (\$\"loss-percent\" / 10)\
\n\
\n:local lcomment \$comment\
\n\
\n\
\n:local lrttavg (\$\"rtt-avg\" / 1000)\
\n:if ((\$\"rtt-avg\" % 1000) > 0) do={ :set lrttavg (\$lrttavg + 1) }\
\n\
\n:local netwatchID ([find where host=\$lhost and type=icmp]->0)\
\n:local nthravg [:tonum ([get \$netwatchID thr-avg ] * 1000)\
\n:local nthrlosspcnt ([get \$netwatchID thr-loss-percent] / 10)\
\n\
\n:log info \"Netwatch \$comment at \$thisBox detected a \$lstatus conditi\
on to host \$lhost. \\\
\n The rtt-avg was \$\"lrttavg\"ms and the loss-percent was \$ll\
osspercent%. \\\
\n The thresholds are thr-avg of \$\"nthravg\"ms and loss-perce\
nt of \$nthrlosspcnt%\"\
\n\
\n#:log info \"netwatch this is a test of logging action disknetwatch\"\
\n\
\n#:tool e-mail send to=<USER>@<DOMAIN>.com subject=\"\$thisBox \$lstat\
us to \$lhost\" body=( [ :system clock get date ] . \" \" . [ :system cloc\
k get time ] . \" \" . \"\$thisBox \$lstatus to \$lhost with rtt-avg of \
\$lrttavg and loss-percent of \$llosspercent%\" )\
\n\
\n:tool e-mail send to=<USER>@<DOMAIN>.com subject=\"\$thisBox \$lstatu\
s to \$lhost\" body=( [ :system clock get date ] . \" \" . [ :system clock\
\_get time ] . \" \" . \"\$comment \$thisBox \$lstatus to \$lhost with rt\
t-avg of \$lrttavg and loss-percent of \$llosspercent%. The thresholds ar\
e thr-avg of \$\"nthravg\"ms and loss-percent of \$nthrlosspcnt%.\" )"
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool netwatch
add comment=Netwatch-1.1.1.1 disabled=no down-script=netwatch-5-2025 host=\
1.1.1.1 interval=5m test-script="" type=icmp up-script=netwatch-5-2025
/tool romon
set enabled=yes
