Product Request: MikroTik should sell a "physical eSIM" for older devices (or suggest some 3rd-party eSIM)
A1 is my provider indirectly. Here is the provider checklist article for switching to a new smartphone. Regarding esim it basically describes: first you have to remove the esim from the old device and then you scan the existing qrcode (“QR-Code nochmals scannen”) with your new smartphone.
Here the quote:
Verwendest du die digitale eSIM, so musst du diese zuerst vom bestehenden Smartphone entfernen und kannst anschließend mit dem neuen Smartphone den QR-Code nochmals scannen – diesen findest du in Mein A1 > (deine Rufnummer) Details anzeigen > Meine SIM-Karten.
https://www.a1blog.net/smartphones/checkliste-neues-smartphone
Is there any update of using sysmocom EUICC1-C2G, 9esim cards for /interface/lte/esim/provision management?
to sum up previous responses, both esim.me and EIOTCLUB cards do it as well.
I am using 9esim one and it works just fine here. Same should be for sysmocom one as it’s just a standard eUICC chip in SIM form factor.
I’d avoid esim.me and 5ber ones though, as their model relies on licensing. While esim.me might work at the moment, there is no guarantee they won’t try to change this in future by modifying Applet IDs like 5ber did.
Generally speaking, they all should work as there is no magic sauce here. Some of these might be trying to force their licensing by using custom Applet IDs (like 5ber does) which would stop them from working with MikroTik, but you could still provision them manually on PC with modified lpac to account for modified IDs.
If anyone is interested, EIOTCLUB has a discount code “EIOTESIM” which lowers the price to 13,93$ with free shipping to Europe or the US.
Or 17,43$ with USB adapter “R301-B9” which, if is just an OEM Feitian hardware, might be compatible with other smartcards (and in my EU country is sold by e-signature providers for like 25-30$).
R11e-LTE6 with 9eSIM V3, FW all latest testing version
i have two eSIM profiles on my eSIM, when i try to activate one it failed: busy
any ideas what’s the problem?
What does it mean
FG621-EA yes* Can't manage empty eSIM (no profiles)
Does this mean that ONLY an empty SIM can't be managed? Or does it actually mean it generally can't add profiles, so even if your eSIM has a profile, you still cannot add a new profile?
Last message is one year old but I could not find a definitive answer whether 9eSIM cards worked without an app.
I managed to use an 9eSIM V0 (480 KB, 15 profiles) with the Chateau LTE12 (2025) (D53G-5HacD2HnD&EG120K-EA / 7.24.1). I did not need anything other than the Mikrotik device in which I directly inserted the physical eSIM card. The router had another access to the Internet during setup, which is needed for provisioning the eSIM.
I ordered a plan from Nomad to test and it worked without too much pain.
I did not test adding multiple profiles, switching between profiles or deleting profiles.
Here is the process I followed.
Upon inserting the eSIM, I tried to check esim-id (which did not work without the eSIM).
[admin@Chateau] > /interface/lte/esim/esim-id lte1
  eid: 890xxxxxxxxxxxxxxxxxxxxxxxx00147
I installed the eSIM profile from Nomad.
[admin@Chateau] > /interface/lte/esim/provision lte1 sm-dp-plus=some.endpoint.from.nomad.com matching-id=8DXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX7BFA
   iccid: 893xxxxxxxxxxxxxx415
     spn: NOMAD
It asked to approve with y (not capital Y, else it says the user denied the activation). Then I got the message "Sending chunk 1/47 to eSIM". It took 20 seconds or so.
The eSIM is there but Nomad website reports that the plan is not yet active.
[admin@Chateau] > /interface/lte/esim/print        Flags: A - ACTIVE
Columns: INTERFACE, NAME, SPN, ICCID
#   INTERFACE  NAME   SPN                   ICCID
0 A lte1       NOMAD  NOMAD  893xxxxxxxxxxxxxx415
It took a while, multiple setting changes and reverting back to default via WinBox, a reboot or two... Before it actually worked. I used the default APN profile, allowed roaming (since the beginning). I think that the eSIM was not yet totally ready: I bought it and immediately tried to use it, within 5 minutes maybe. After 10-15 minutes it worked as expected.
In the meantime, I would get errors like the one below and others stating that no GPRS network was available and that the device failed to register on the network
lte1 mbim: packet service: detached data class: 0, nwe: GPRS services not allowed in this PLMN
It worked with the modem using its default configuration.
[admin@Chateau] > /interface/lte/settings/print
                 mode: auto
         esim-channel: auto
        firmware-path: firmware
  link-recovery-timer: 120
     external-antenna: none
LTE was connected as expected.
[admin@Chateau] > /interface/lte/monitor lte1
            status: running
             model: EG120K-EA
          revision: EG120KEAAAR01A10M2G
  current-operator: Proximus
           roaming: yes
    current-cellid: 10xxxxx77
            enb-id: 4xxxx1
         sector-id: 121
        phy-cellid: 290
        data-class: LTE
    session-uptime: 4m3s
              imei: 86xxxxxxxxxxx62
              imsi: 20xxxxxxxxxxx41
             iccid: 89xxxxxxxxxxxxxxxx15
      primary-band: B3@20Mhz earfcn: 1300 phy-cellid: 290
     dl-modulation: qpsk
               cqi: 13
                ri: 2
               mcs: 1
              rssi: -57dBm
              rsrp: -88dBm
              rsrq: -9dB
              sinr: 15dB
Internet access worked and I got a decent speed for LTE in my area.
[admin@Chateau] > ping 1.1.1.1 interface=lte1
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 1.1.1.1                                    56  60 51ms573us
    1 1.1.1.1                                    56  60 56ms403us
    2 1.1.1.1                                    56  60 64ms696us
    sent=3 received=3 packet-loss=0% min-rtt=51ms573us avg-rtt=57ms557us max-rtt=64ms696us
user@linux-machine$ speedtest
Retrieving speedtest.net configuration...
Testing from Belgacom International Carrier Services (80.84.28.117)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Exa Networks Limited (Bradford) [528.22 km]: 89.579 ms
Testing download speed................................................................................
Download: 82.96 Mbit/s
Testing upload speed......................................................................................................
Upload: 33.18 Mbit/s
