Product Request: MikroTik should sell a "physical eSIM" for older devices (or suggest some 3rd-party eSIM)
On Prime Day it was 20EUR including the reader. :upside_down_face:
Is it even possible to reuse same prov. profile after it has been deleted or always new needs to be issued? Maybe this can depend on MNO rules.
I have not found a way to re-provision this esim profile I had deleted. Seems to be a security measure that can’t be worked around. I went to the self service section and ordered a eSIM exchange. Usually they send it immediately by e-mail, but because I can’t receive a TAN SMS anymore this has to be shipped by post. “Glad” this service is free. But a PITA.
I hope Mikrotik can reproduce the issue I reported them. So they can fix the issue and no one has to waste 2h on this nonsense.
From expirence, when I needed to switch to new iPhone, my carrier did not support eSIM transfer, when profile has been deleted from old device, on new it was not possible to activate same profile, I needed to contact them to give me new profile QR for same plan to activate it.
Not sure if MT can do anything about it if is the same case.
eSIM profiles are single provision only. Even if it was deregistered properly you would not be able to provision it again on any device using same code. In either case you need to have your provider generate new provisioning code for you.
The deregistered state is of very little matter in truth. It just informs provider that you have removed eSIM from your device. In majority cases this will means that provider will block self-replacement (for migrating to new device) option on their app/website as those usually require SMS confirmation and that would be impossible if you don’t have profile installed anymore. It is also not mandatory to de-register first (think about how your phone with eSIM profile on it could’ve been lost or broke) for provider to generate new provisioning code (via invalidating old profile).
My experience I already transferred eSIM between different Android phones. All I had to do is to remove/release the eSIM on phone A so I could use it on phone B. No problem at all. As long device does unregister it correctly.
Excuse me, but my personal experience is different. I can and have already used the exact same eSIM “credentials” and used them on different phones. It is like swapping physical SIM to another device. Just virtually. Only requirement: I could not have the same eSIM profile active on more than one device. Once I removed eSIM profile from e.g. phone A, it was accepted on phone B. No problem at all.
Might I know what is your provider here? It is extremely rare to accept same provisioning code that was already used and I would actually consider it security issue (even with added protection of checking deregistered state). Pretty much everyone in industry has agreed that one-time provisioning codes are the way to go.
Even if it works with your current provider, do be aware that majority of them will not have same behavior.
The provider is yesss!, a sub carrier of A1 in Austria.
But I have to double check. I usually download the esim pdf every time I switch devices. Need to check if security code changes.
If you download new PDF then it is likely new provisioning code. Have you downloaded new PDF this time too? I would imagine typical flow be:
  1. Log in to provider website
  2. Request eSIM swap
  3. Receive confirmation code via SMS
  4. Download PDF instructions
Then you would simply provision that on new phone, which would instantly invalidate old profile (if still installed) on previous device. There is little reason to check for deregistered status at this point if you already have to confirm via SMS and provisioning code is valid for short time (usually 12 to 24 hours). It has added benefit of avoiding losing your number should registration on new phone failed somehow after you already deregistered on old one.
Nasty.
Or maybe the new profile has something “unique” different (similar to a MAC or GUID) from the original one, possibly only - say - date/time of creation and the eSIM remains linked to the old one.
But I believed than from a “full” OS (running the eSIM manufacturer app) it was possible to de-activate/unlink the eSIM from any device (possibly using a PIN, a PUK or something like that), if I were you I would also ask for clarifications with the eSIM manufacturer.
The same misadventure that happened to you (very likely caused by something missing or incompatible with your eSIM in Mikrotik software) could happen also if the device - for one reason or the other - dies.
You may have an identical one that you could easily swap, but if you cannot transfer the eSIM from the dead device to the replacement unit it seems to me a not-so-trifling problem.
This is basically the process at my other provider (bob.at). I log in, request a eSIM swap, need to verify by a TAN received by SMS and done. Unfortunately I can not receiver the SMS, because it is the one that was deleted. So I need to wait for the new eSIM instructions mailed by post. Should arrive in a few days.
No. I can view or download the esim instructions as many times I want. The codes are always the same. They only change when I request a eSIM exchange.
Honestly I think this is not an eSIM card manufacturer issue here. For me it looks like a missing safe-guard in either ROS or Qualcomm firmware.
What do you mean? I have no new profile. I deleted the profile on the Mikrotik device and now it can’t be used anywhere else. The provider still thinks the profile is assigned to a device and does not allow provisioning this profile anywhere else.
eider suggested to use the other approach: invalidate the current profile by requesting a esim profile exchange at the provider. So you cant end up like in my case. You have a new profile and the old one goes inactive/invalid/expired by itself. Lesson learned.
The fun part is: both bob.at and yesss.at are brands of A1 Austria. Bob offers eSIM change as self service and works immediately free of charge. With yesss! it costs 9EUR every time I like to request a new eSIM profile. THB this sounds like not reflecting the actual costs that are probably none to zero.
In all honesty, 9 EUR is still nothing for the complex process which is behind it, even if completely automated.
It is an automated process. Cellular infrastructure is even more complex than eSIM, and it costs not 9eur for every phone call.
And eSIM is a replacement for physical SIM. A physical SIM I can put in any device I like and I can make that the whole day long. And im theory I could also do that game when ROS actually have contacted the SM-DP+ to update the status of the profile. But some part of unknown piece did not do that and now it is game over. I have a virtual SIM stuck in the void. Like a physical SIM stuck in the SIM reader and not able to eject it and device not able to read it anymore. And then there are some like eider who say, a esim profile can only be activated once. On every device change you need to issue a new profile. And for this I should pay 9EUR every time? Like 9EUR every time I put a regular SIM in a different phone? Nobody would accept that.
Hmmm, yes and no… automated phone calls have been possible already for soo long.
(I used to work for Alcatel for quite a long time, they made huge amounts of telephony exchange centrals)
Even when cellular calls where added to the central switching systems, it didn’t require them to do things differently (from a switching point of view).
Volumes of cellular calls are accounting for quite a bit of payback as well (GSM started when, around early '90s if I recall ?)
This whole eSIM management process is something which had to be made from ground up quite recently.
Whether it’s commercially a sensible decision to charge for it, that I will leave in the middle (but honestly, I think it should be a service for the customer).
So let the market play and decide as a customer if you want to stay with a provider who charges you 9 EUR for this.
My provider apparently thinks that I use devices that properly report esim profile status to the SM-DP+ server. Everything else is treated as “lost esim” or “lost device” or similar. Like when you loos a physical regular SIM card. They charge you for the new chip card in most cases.
In the regular process of esim profile deletion it is usually de-registered properly and I can use the same profile in any other device again. It would make the whole esim thing ridiculous when I would have to insert coins every time I want to transfer esim profile to another device. That would be a complete downgrade and virtually insane.
