Apologies if this already has been suggested elsewhere, but beyond a two port high performance router (http://forum.mikrotik.com/t/hardware-idea-for-two-port-high-performance-router/160804/1), I didn’t find anything too relevant.
When planning the evolution of my network I seem to be hitting a gap in the current lineup, as I don’t need a large port density because due to wiring constraints I find my topology more leafed out, but still would like a 10Gbps backbone to aggregate to my WAN.
The new CRS310-8G+2S+ (219$) I think is great addition for my use case. Same goes for the CRS309-1G-8S+ (269$) for L3HW FastTrack and NAT for intervlan routing in the core or CSS610-8G-2S+IN as a relatively cost efficient access switch for 1GbE clients (119$).
But a companion router for my fiber connection and VPN tunnels seems to be missing. I can’t imagine I’m the only one who finds themself presented with such a scenario.
What I would like is a router that has:
=10Gbps routing potential
- =<10" rack form factor, ideally RMK-2/10 compatible
= 2 SFP+ slots for an XGSPON module and switch uplink
- 1GbE management port
- sufficient CPU for 1Gbps VPN tunnels (Wireguard, IPSec), OSPF, BGP, multicast routing and the odd container
I think my current ideal would really be CRS309-1G-8S+ port configuration in a CRS310 formfactor and the CCR2004-1G-12S+2XS block diagram.
In the current lineup I feel:
- The RB5009UG+S+IN is close but falls short on the >2 SFP+ port requirement. Pricewise, 219$ is very competitive.
- The CCR2004-16G-2S+ sitting at 465$ is a 112% cost increase, that buys you 16x1GbE that you can’t get in the same L2 plane as the SFP+ ports (AFAIK not without using a CPU bridge anyway; to work with the downstream switch handling intervlan routing) while occupying a full 1U of scarce rack space.
- The CCR2004-1G-12S+2XS is again more expensive at 595$. It will probably be the last router I need (provided the hardware doesn’t fail at some point), but at a hefty investment sum, excessive port count and again full 1U.
For a better differentiator to the latter, perhaps the CRS310-1G-5S-4S+ port configuration for the proposed router is better marketingwise. Don’t know about the manufacturing economics, but I’d say at 300-350$ halfway between the RB5009UG+S+IN and CCR2004-16G-2S+ would be a nice pricepoint considering the current lineup (only occupied by the RB1100AHx4 having an entirely different feature set). That’s however all for @Normis c.s. to research.
“But, if you’re going to put them in a rack together anyway, why not pick a CCR2004-1G-12S+2XS for the combined cost of router and switch”, you ask? a) no hardware switchchip and b) >1GbE SFP(+) copper modules are expensive and run hot, so IMO it would then still be more economical to add a CRS310-8G+2S+.
One could further reduce the port count to go into RB5009 or even CRS305 form factors, but I imagine thermal management will become an issue.
