Proof that IPQ-5010 can run ARM 64bit RouterOS
I came along these two new devices (see links below) which have an IPQ-5010 cpu and run 64 bit RouterOS.
So there is hope one day we can get a 64 bit OS for the SXTsq 5 ax, wAP ax or even hAP ax lite.
New devices:
https://mikrotik.com/product/knot_gateway_lr8#product_specification
https://mikrotik.com/product/knot_gateway_hl#product_specification
Related:
https://mikrotik.com/product/sxtsq_5ax
Product code | SXTsq-5axD
Suggested price | $65.00
Architecture | ARM 32bit
CPU | IPQ-5010
Hope with MikroTik usually ends in frustration.
What is particular reason for having ARM64 ROS on these mentioned devices? You can get small gain in CPU performance (approx. 10-15%) but much larger RAM consumption (in some cases double per allocation) with this architecture and these devices doesn't have much RAM to spare.
Since there is no wifi on linked devices example (knot devices) with same SoC I guess MT decided for ARM64 ROS to get max CPU performance since largest RAM consumption is wifi driver which is not running on them.
Only ROS package that is unavailable on 32-bit ARM is app (along with extra nic and marvell switch drivers) which can be compensated with manually created containers if you really need some service from apps list.
Actually, they support /app on ARM32 just with a reduced catalog, and thus not able to run ARM64 containers. But the limit memory on these "IPQ-5010" devices is what kills using containers, more than OS arch.... And even the "ARM64" release still contains many ARM32 modules inside the package.
But @optio's question is a good one:
"What is particular reason for having ARM64 ROS on these mentioned devices?".
Since AFAIK the only possible benefit is SNMP and counter are longer, but I'm not even sure that's true. Maybe some reason help here, since even if possible... you're now not running the device the same as it used by others and tested, so that be big risk if you ask me. And that's on top of the that these start with with limited RAM/"disk", so not like some untapped power waiting to be unleashed here...
Still some services with low memory usage can be run, I was running on Chateau LTE12 with 256MB of RAM (IPQ-4019 / 32-bit ARM) Unbound (had to heavy tweak config for device) and Pi-Hole containers w/o RAM issues and with wifi-qcom-ac package, until some ROS version introduced storage issues on 16MB flash.
32 or 64 bit long counters are independand from 32/64 architecture. It's just a matter of count of CPU instructions needed to update them.
Both linked devices have 2.4 GHz Wi-Fi 6 (802.11b/g/n/ax).
True, overlooked that while looking at specs, still I there is some differences in Wifi specs between devices, hAP ax lite has as Knot devices only 2.4GHz Wifi interface but with 2 chains which gives more speed for what more RAM is needed by wifi driver, while SXTsq 5 ax has 5GHz and wAP ax 2.4 and 5GHz, also on both more speed, IMO that could be tradeoff by MT to use 32-bit architecture OS on these devices with low RAM to avoid OOM kernel crashes.
I guess my question remains what do you think 64-bit RouterOS would help?
