Drageir
November 11, 2020, 12:48pm
1
Greetings everyone.
I have 2 VLANs, one for the office and another for my guest’s WiFi.
office_vlan: 192.168.50.0
guest_vlan: 192.168.40.0
I’ve managed to block the traffic coming from guest_wifi to office_wifi, but when a port is specified, it conects.
For example:
I’m connected to guest_vlan (192.168.40.19) and I can’t connect to my main server at 192.168.50.36, but if I write 192.168.50.36:8002, I can enter without reservations.
Reading about my problem on the web, I tried a Firewall Rule:
Chain: forward
Dst. Address: 192.168.50.36
Protocol: 6 (tcp)
Dst. Port: 8002
In. Interface: ether2 #Guest_WiFi interface
Out. Interface: bridge1 #Office_vlan interface
Action: drop
But it makes nothing.
Thank you for your time.
anav
November 11, 2020, 1:28pm
2
Drageir
November 11, 2020, 3:15pm
3
# nov/11/2020 16:01:07 by RouterOS 6.45.8
# software id = 49EJ-U4T5
# model = 750GL
# serial number = 467A0460B26D
add admin-mac=4C:5E:0C:E1:9B:EE arp=proxy-arp auto-mac=no comment=\
"created from master port" name=bridge1 protocol-mode=none
add disabled=yes name=bridge_invitados
set [ find default-name=ether1 ] name=ether1-gateway speed=100Mbps
set [ find default-name=ether2 ] name=ether2-master-local speed=100Mbps
set [ find default-name=ether3 ] name=ether3-slave-local speed=100Mbps
set [ find default-name=ether4 ] name=ether4-slave-local speed=100Mbps
set [ find default-name=ether5 ] name=ether5-slave-local speed=100Mbps
/interface vlan
add interface=ether1-gateway name=vlan3 vlan-id=3
add interface=ether1-gateway name=vlan6 vlan-id=6
add interface=ether1-gateway name=vlan200 vlan-id=200
add interface=ether2-master-local name=vlan_invitados use-service-tag=yes \
vlan-id=20
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan6 keepalive-timeout=60 \
max-mru=1492 max-mtu=1492 name=pppoe-out1 user=adslppp@telefonicanetpa
add name=WAN
add name=LAN
add name=LAN2
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed mode=dynamic-keys name=4G \
supplicant-identity=""
/ip firewall layer7-protocol
add name=Proteccion_invitados
/ip ipsec profile
add dh-group=modp1024 name=profile_1
add dh-group=modp1024 name=profile_2
add dh-group=modp1024 name=profile_3
add dh-group=modp1024 enc-algorithm=3des name=profile_4
/ip ipsec peer
# This entry is unreachable
add name=peer4 passive=yes profile=profile_4
add name=peer3 passive=yes profile=profile_3
add name=peer2 passive=yes profile=profile_2
add name=peer1 passive=yes profile=profile_1
add name=dhcp ranges=192.168.10.121-192.168.10.200
add name=vpn ranges=192.168.10.214-192.168.10.234
add name=l2tp-pool ranges=192.168.10.220-192.168.10.225
add name=dhcp_pool3_invi ranges=192.168.20.2-192.168.20.254
add name=hs-pool-9 ranges=10.5.50.2-10.5.50.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
bridge1 name=dhcp1
add address-pool=dhcp_pool3_invi authoritative=after-2sec-delay disabled=no \
interface=bridge_invitados lease-time=10s name=dhcp_invitados
add address-pool=hs-pool-9 disabled=no interface=ether2-master-local \
lease-time=1h name=dhcp2
/ip hotspot user profile
set [ find default=yes ] address-pool=dhcp_pool3_invi shared-users=2
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8 local-address=192.168.10.1 name=\
l2tp remote-address=l2tp-pool use-encryption=yes
add local-address=192.168.10.1 name=openvpn remote-address=l2tp-pool
add dns-server=8.8.8.8 local-address=192.168.10.1 name=vpn remote-address=vpn \
use-encryption=yes wins-server=8.8.4.4
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/system logging action
set 0 memory-lines=1
add bridge=bridge1 interface=ether3-slave-local
add bridge=bridge1 interface=ether4-slave-local
add bridge=bridge1 interface=ether5-slave-local
add bridge=bridge_invitados interface=ether2-master-local pvid=20
/interface l2tp-server server
set authentication=mschap2 enabled=yes max-mru=1460 max-mtu=1460 mrru=1600 \
use-ipsec=yes
add interface=ether1-gateway list=WAN
add interface=ether2-master-local list=LAN2
/interface ovpn-server server
set certificate=mikrotik cipher=blowfish128,aes128,aes192,aes256 \
require-client-certificate=yes
/interface pptp-server server
set enabled=yes keepalive-timeout=180 max-mru=1500 max-mtu=1500
add address=192.168.10.1/24 interface=bridge1 network=192.168.10.0
add address=192.168.100.10/24 interface=ether1-gateway network=192.168.100.0
add address=217.124.116.61/29 interface=ether1-gateway network=217.124.116.56
add address=10.5.50.1/24 disabled=yes interface=bridge_invitados network=\
10.5.50.0
add address=10.5.50.1/24 comment="hotspot network" interface=\
ether2-master-local network=10.5.50.0
add address=192.168.100.12 interface=ether2-master-local network=\
192.168.100.0
/ip arp
add address=192.168.10.40 interface=bridge1 mac-address=D8:CB:8A:9C:19:06
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
interface=vlan3 use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.10.172 always-broadcast=yes mac-address=BC:83:85:D4:CF:EC \
server=dhcp1
add address=192.168.10.6 mac-address=68:FF:7B:44:C0:E8
add address=192.168.10.5 mac-address=68:FF:7B:44:BE:D8
add address=10.5.50.0/24 comment="hotspot network" gateway=10.5.50.1
add address=192.168.10.0/24 dns-server=192.168.10.205 gateway=192.168.10.1 \
netmask=24
add address=192.168.20.0/24 dns-server=192.168.20.1,8.8.8.8 gateway=\
192.168.20.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4,1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.10.1 name=router
/ip firewall address-list
add address=192.5.50.0/24 list=Invitados
add address=192.168.10.0/24 list=Interno
add address=192.168.10.221 list=Prox
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=accept chain=input comment="default configuration" \
connection-state=established
connection-state=related
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input disabled=yes dst-port=23,80 in-interface=\
pppoe-out1 protocol=tcp
add action=accept chain=input disabled=yes dst-port=8291 in-interface=\
all-ethernet protocol=tcp
add action=accept chain=input dst-port=1723 in-interface=all-ethernet \
protocol=tcp
add action=accept chain=forward comment="default configuration" \
add action=accept chain=input dst-port=1701 in-interface=all-ethernet \
protocol=udp
add action=accept chain=input dst-port=500 in-interface=all-ethernet \
protocol=udp
add action=accept chain=input in-interface=all-ethernet protocol=ipsec-ah
add action=accept chain=input dst-port=4500 in-interface=all-ethernet \
protocol=udp
add action=accept chain=input in-interface=all-ethernet protocol=ipsec-esp
add action=accept chain=input in-interface=all-ethernet protocol=gre
add action=accept chain=input disabled=yes dst-port=1194 protocol=tcp
add action=accept chain=input disabled=yes protocol=udp src-port=1194
add action=accept chain=input disabled=yes protocol=tcp src-port=50000-65000
add action=drop chain=input comment="default configuration" disabled=yes \
in-interface=pppoe-out1 log-prefix=rechazadas
add action=drop chain=forward comment="default configuration" \
connection-state=invalid disabled=yes log-prefix=forw
add action=drop chain=forward disabled=yes src-address=192.168.10.21
add action=fasttrack-connection chain=forward comment="Fasttrack DNS" \
dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward comment="Fasttrack DNS UDP" \
dst-port=53 protocol=udp
add action=accept chain=forward dst-port=9998 in-interface=all-ethernet \
protocol=tcp src-port=9998
out-interface=all-ethernet protocol=udp src-port=9998
"Invitados no puedan entrar en router" disabled=yes in-interface=\
vlan_invitados out-interface=vlan3
add action=accept chain=output disabled=yes dst-address=192.168.100.0/24 \
src-address=10.5.50.0/24
add action=accept chain=forward in-interface=all-ethernet src-address-list=\
Invitados
add action=accept chain=forward connection-state="" src-address-list=Interno
add action=drop chain=forward comment="Bloquear tr\E1fico para invitados" \
in-interface=ether2-master-local out-interface=bridge1
"Bloquear puerto de Proxmox para invitados" dst-address=192.168.10.221 \
dst-port=8006 in-interface=ether2-master-local out-interface=bridge1 \
protocol=tcp
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=4 out-interface=vlan3 \
passthrough=yes
add action=set-priority chain=postrouting new-priority=1 out-interface=\
all-ethernet passthrough=yes
add action=set-priority chain=postrouting new-priority=4 out-interface=\
all-vlan passthrough=yes
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=ether1-gateway
out-interface=vlan3
add action=dst-nat chain=dstnat comment="Mapeo Servidor - 443" dst-port=443 \
in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.243
add action=dst-nat chain=dstnat comment="CERT SAIT" disabled=yes dst-port=443 \
in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.215
add action=dst-nat chain=dstnat comment="Mapeo Servidor O- 443" disabled=yes \
dst-port=443 in-interface=all-ethernet protocol=tcp to-addresses=\
192.168.10.214
add action=dst-nat chain=dstnat comment="Mapeo Servidor O- 445" dst-port=445 \
in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.216 \
to-ports=445
add action=dst-nat chain=dstnat comment="Mapeo Servidor Nextcloud - 443" \
disabled=yes dst-port=443 in-interface=pppoe-out1 protocol=tcp \
to-addresses=192.168.10.213
add action=dst-nat chain=dstnat comment="R renovacion CERT Office" disabled=\
yes dst-port=80 in-interface=pppoe-out1 protocol=tcp to-addresses=\
192.168.10.216
add action=dst-nat chain=dstnat comment="Mapeo Servidor Nextcloud - 9980" \
disabled=yes dst-port=9980 in-interface=all-ethernet protocol=tcp \
to-addresses=192.168.10.131
add action=dst-nat chain=dstnat comment="Puerto SMTP SSL" dst-port=465 \
in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.243 \
to-ports=465
add action=dst-nat chain=dstnat comment="Puerto SMTP" dst-port=25 \
to-ports=25
add action=dst-nat chain=dstnat comment="Puerto SSH" dst-port=22 \
in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.213 \
to-ports=22
add action=dst-nat chain=dstnat comment="Puerto SSH" dst-port=81 \
in-interface=all-ethernet protocol=tcp src-port="" to-addresses=\
192.168.10.212 to-ports=80
add action=dst-nat chain=dstnat comment="Redireccion Owncloud" dst-port=444 \
to-ports=443
add action=dst-nat chain=dstnat comment=\
"Network News Transfer Protocol (NNTP)" dst-port=119 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.243 to-ports=119
add action=dst-nat chain=dstnat comment="Mail Transfer Agent (MTA)" dst-port=\
102 in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.243 \
to-ports=102
add action=dst-nat chain=dstnat comment="Domain Name System (DNS)" dst-port=\
53 in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.243 \
to-ports=53
add action=dst-nat chain=dstnat comment="Remote Procedure Protocol (RPC)" \
dst-port=135 in-interface=all-ethernet protocol=tcp to-addresses=\
192.168.10.243 to-ports=135
add action=dst-nat chain=dstnat comment="SSL secured NNTP" dst-port=563 \
to-ports=563
"LDAP communications with an Active Directory Global Catalog Server" \
dst-port=3268 in-interface=all-ethernet protocol=tcp to-addresses=\
192.168.10.243 to-ports=3268
add action=dst-nat chain=dstnat comment=WEBMAIL dst-port=80 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.243 to-ports=443
add action=dst-nat chain=dstnat comment="CERT ITSA" disabled=yes dst-port=80 \
in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.10.215 \
to-ports=80
add action=dst-nat chain=dstnat comment=WEBMAIL disabled=yes dst-port=4422 \
in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.10.213 \
to-ports=4422
add action=dst-nat chain=dstnat dst-port=4423 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.216 to-ports=4423
add action=dst-nat chain=dstnat disabled=yes dst-port=4424 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.10.214 to-ports=4424
add action=dst-nat chain=dstnat dst-port=37777 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.49 to-ports=37777
add action=dst-nat chain=dstnat comment="WEBMAIL 2" disabled=yes dst-port=\
8080 in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.200 \
to-ports=8080
add action=dst-nat chain=dstnat comment="Puerto STARTTLS" dst-port=587 \
to-ports=587
add action=dst-nat chain=dstnat comment="Puerto IMAP SSL" dst-port=993 \
to-ports=993
add action=dst-nat chain=dstnat comment="Puerto POP SSL" dst-port=995 \
to-ports=995
add action=dst-nat chain=dstnat comment="Puerto IMAP" dst-port=143 \
to-ports=143
add action=dst-nat chain=dstnat comment="Puerto POP" dst-port=110 \
to-ports=110
add action=dst-nat chain=dstnat comment="Mapeo Servidor .200- WAN1" disabled=\
yes dst-port=3395 in-interface=pppoe-out1 protocol=tcp to-addresses=\
192.168.10.200 to-ports=3395
add action=dst-nat chain=dstnat disabled=yes dst-port=3398 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.10.205 to-ports=3398
add action=dst-nat chain=dstnat dst-port=56994 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.49 to-ports=3399
add action=dst-nat chain=dstnat dst-port=56856 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.52 to-ports=3340
add action=dst-nat chain=dstnat dst-port=56022 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.216 to-ports=56022
add action=dst-nat chain=dstnat disabled=yes dst-port=3397 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.10.209 to-ports=3397
add action=dst-nat chain=dstnat comment="Mapeo Servidor EX- WAN1" disabled=\
yes dst-port=4443 in-interface=all-ethernet protocol=tcp to-addresses=\
192.168.10.243 to-ports=4443
add action=dst-nat chain=dstnat comment="Mapeo Servidor EX- WAN1" dst-port=\
3010 in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.101 \
to-ports=3010
3011 in-interface=all-ethernet protocol=tcp to-addresses=192.168.10.101 \
to-ports=3011
3010 in-interface=all-ethernet protocol=udp to-addresses=192.168.10.101 \
to-ports=3010
3011 in-interface=all-ethernet protocol=udp to-addresses=192.168.10.101 \
to-ports=3011
add action=dst-nat chain=dstnat comment="Mapeo Servidor AD" disabled=yes \
dst-port=3394 in-interface=pppoe-out1 protocol=tcp to-addresses=\
192.168.10.245 to-ports=3394
add action=dst-nat chain=dstnat dst-port=6767 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.20 to-ports=6767
add action=dst-nat chain=dstnat dst-port=20 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.20 to-ports=20
add action=dst-nat chain=dstnat dst-port=8090 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.150 to-ports=8090
protocol=udp to-addresses=192.168.10.150 to-ports=8090
add action=dst-nat chain=dstnat dst-port=3080 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.150 to-ports=3080
protocol=udp to-addresses=192.168.10.150 to-ports=3080
add action=dst-nat chain=dstnat dst-port=7000 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.150 to-ports=7000
protocol=udp to-addresses=192.168.10.150 to-ports=7000
add action=dst-nat chain=dstnat dst-port=8000 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.150 to-ports=8000
protocol=udp to-addresses=192.168.10.150 to-ports=8000
add action=dst-nat chain=dstnat dst-port=9000 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.150 to-ports=9000
protocol=udp to-addresses=192.168.10.150 to-ports=9000
add action=dst-nat chain=dstnat dst-port=10510 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.150 to-ports=10510
protocol=udp to-addresses=192.168.10.150 to-ports=10510
add action=dst-nat chain=dstnat dst-port=8091 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.151 to-ports=8091
protocol=udp to-addresses=192.168.10.151 to-ports=8091
add action=dst-nat chain=dstnat dst-port=3081 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.151 to-ports=3081
protocol=udp to-addresses=192.168.10.151 to-ports=3081
add action=dst-nat chain=dstnat disabled=yes dst-port=7001 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.10.151 to-ports=7001
pppoe-out1 protocol=udp to-addresses=192.168.10.151 to-ports=7001
add action=dst-nat chain=dstnat disabled=yes dst-port=8001 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.151 to-ports=8001
all-ethernet protocol=udp to-addresses=192.168.10.151 to-ports=8001
add action=dst-nat chain=dstnat dst-port=9001 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.151 to-ports=9001
protocol=udp to-addresses=192.168.10.151 to-ports=9001
add action=dst-nat chain=dstnat dst-port=10520 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.151 to-ports=10520
protocol=udp to-addresses=192.168.10.151 to-ports=10520
add action=dst-nat chain=dstnat disabled=yes dst-port=3389 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.19 to-ports=3389
all-ethernet protocol=udp to-addresses=192.168.10.19 to-ports=3389
add action=dst-nat chain=dstnat dst-port=44444-44445 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.19 to-ports=44444-44445
add action=dst-nat chain=dstnat dst-port=56529 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.21 to-ports=3393
add action=dst-nat chain=dstnat disabled=yes dst-port=3396 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.10.46 to-ports=3396
add action=dst-nat chain=dstnat comment="admin remota 2" disabled=yes \
dst-port=8291 in-interface=all-ethernet protocol=tcp to-addresses=\
192.168.10.1 to-ports=8291
add action=dst-nat chain=dstnat disabled=yes in-interface=all-ethernet \
protocol=ipsec-ah to-addresses=192.168.10.1
protocol=ipsec-esp to-addresses=192.168.10.1
add action=dst-nat chain=dstnat comment=IPSEC dst-port=500 in-interface=\
all-ethernet protocol=udp to-addresses=192.168.10.1 to-ports=500
add action=dst-nat chain=dstnat comment=L2TP dst-port=1701 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.1 to-ports=1701
add action=dst-nat chain=dstnat dst-port=4233 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.221 to-ports=22
protocol=gre to-addresses=192.168.10.1
add action=dst-nat chain=dstnat comment=PPTP dst-port=1723 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.1 to-ports=1723
all-ethernet protocol=udp to-addresses=192.168.10.19 to-ports=44444-44445
add action=dst-nat chain=dstnat dst-port=3333-3334 in-interface=all-ethernet \
protocol=udp to-addresses=192.168.10.33 to-ports=3333-3334
add action=dst-nat chain=dstnat disabled=yes dst-port=3390 in-interface=\
all-ethernet protocol=tcp to-addresses=192.168.10.33 to-ports=3390
add action=dst-nat chain=dstnat comment="WEB RENOVAR CERT NUBE" disabled=yes \
192.168.10.213 to-ports=80
add action=dst-nat chain=dstnat comment="WEB RENOVAR CERT SERVICIO" disabled=\
yes dst-port=80 in-interface=all-ethernet protocol=tcp to-addresses=\
192.168.10.219 to-ports=80
all-ethernet protocol=udp to-addresses=192.168.10.35 to-ports=3390
add action=dst-nat chain=dstnat comment="MAPEO SERVIDOR 3 VODAFONE" disabled=\
yes dst-port=5900-5909 in-interface=ether1-gateway protocol=tcp \
to-addresses=192.168.1.131 to-ports=5900-5909
add action=dst-nat chain=dstnat disabled=yes dst-port=47 in-interface=\
all-ethernet protocol=udp to-addresses=192.168.1.20 to-ports=47
add action=dst-nat chain=dstnat dst-port=8060-8070 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.201 to-ports=8060-8070
add action=dst-nat chain=dstnat dst-port=1234 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.120 to-ports=1234
protocol=tcp to-addresses=192.168.10.100 to-ports=10000-10020
add action=dst-nat chain=dstnat comment="SSL secured SMTP" dst-port=26 \
to-ports=26
add action=dst-nat chain=dstnat disabled=yes protocol=tcp src-port=1194 \
add action=dst-nat chain=dstnat dst-port=56443 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.216 to-ports=56443
add action=dst-nat chain=dstnat dst-port=2525 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.243 to-ports=2525
add action=dst-nat chain=dstnat dst-port=717 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.10.243 to-ports=717
add action=accept chain=dstnat dst-address=192.168.1.150 dst-port=9998 \
protocol=tcp
protocol=udp
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
add action=accept chain=dstnat dst-port=3399 protocol=udp
add action=dst-nat chain=dstnat comment=IPSEC dst-port=4500 in-interface=\
all-ethernet protocol=udp to-addresses=192.168.10.1 to-ports=4500
add action=masquerade chain=srcnat src-address=192.168.20.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=yes src-address=10.5.50.0/24
/ip hotspot user
add name=admin
add name=invitado
/ip ipsec identity
# Suggestion to use stronger pre-shared key or different authentication method
add peer=peer1
add peer=peer2
add peer=peer3
add generate-policy=port-override peer=peer4 remote-id=ignore
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip proxy
set enabled=yes
/ip proxy access
add action=deny
add distance=3 gateway=217.124.116.57
add distance=255 gateway=255.255.255.255
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www-ssl disabled=no
set api disabled=yes
set winbox disabled=yes port=44606
set api-ssl disabled=yes
/ip socks
set enabled=yes port=34605
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=pppoe-out1 type=external
/ppp secret
add name=victorl2 profile=l2tp service=l2tp
add name=informatica profile=l2tp
add name=dgarcia profile=l2tp service=l2tp
add name=Bon profile=l2tp service=l2tp
add name=vpn
/routing rip interface
add interface=vlan3 passive=yes receive=v2
/routing rip network
add network=10.0.0.0/8
/system clock
set time-zone-name=Europe/Madrid
/system logging
add topics=l2tp
add disabled=yes topics=ovpn
/system ntp client
set enabled=yes primary-ntp=213.251.52.234 secondary-ntp=46.165.221.137
/system package update
set channel=long-term
/system scheduler
add interval=1d name=Reinicio on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=feb/05/2019 start-time=05:30:00
anav
November 11, 2020, 6:31pm
4
Yeah your config is a bloated mess and 1/2 implementing many things like bridge ports filtering etc.
For example how you can you set more than one dhcp service per port interface…boggles my mind.
Suggestion.
a. download new firmware (long term 6.46.8 )
b. dump your current config save what you need for vpn
c. add back in default firewall rules.
d. implement bridge ports and bridge vlan filtering using this reference.
Then come back here and go from there…
Drageir
November 12, 2020, 8:49am
5
Greetings.
Yes, is a mess -.-". I inherited from the previous technician and I don’t know enought of MikroTik to make it from scratch.
On other topic, I finnally resolved my problem. The only thing I did was to add a Rule in Routes:
Dst. Address: 192.168.10.0/24 #Office Vlan
Interface: bridge_guests
Action: drop
That way EVERYTHING coming from that interface gets dropped when trying to connecto to mi office’s vlan.
Thank you so much for your time.
