ProtonVPN config routing
Hi guys,
I’m using the following config based on NordVPN to connect to ProtonVPN. The connection is established. But whatsmyip shows me my provider’s ip instead of ProtonVPN ip. Can you please help me to figure this out?
/tool fetch url=“https://protonvpn.com/download/ProtonVPN_ike_root.der”
/certificate import file-name=ProtonVPN_ike_root.der
/ip ipsec profile add dh-group=modp4096,modp2048,modp1024 dpd-interval=disable-dpd enc-algorithm=aes-256 hash-algorithm=sha256 name=ProtonVPN
/ip ipsec proposal add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=ProtonVPN pfs-group=none
/ip ipsec policy group add name=ProtonVPN
/ip ipsec policy add dst-address=0.0.0.0/0 group=ProtonVPN proposal=ProtonVPN src-address=0.0.0.0/0 template=yes
/ip ipsec mode-config add connection-mark=ProtonVPN name=ProtonVPN responder=no
/ip ipsec peer add address=nl-free-01.protonvpn.com exchange-mode=ike2 name=ProtonVPN profile=ProtonVPN
/ip ipsec identity add auth-method=eap certificate=“” eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=ProtonVPN password= peer=ProtonVPN policy-template-group=ProtonVPN username=
/ip firewall address-list add address=192.168.88.0/24 list=local
/ip firewall mangle add action=change-mss chain=forward ipsec-policy=in,ipsec new-mss=1382 passthrough=yes protocol=tcp tcp-flags=syn
/ip ipsec mode-config set [ find name=ProtonVPN ] src-address-list=local
/ip ipsec policy move *ffffff destination=0
/ip ipsec policy add action=none dst-address=192.168.88.0/24 src-address=0.0.0.0/0 place-before=1
Last step: delete the ‘defconf fasttrack’ rule from firewall rules.
Yup. http://forum.mikrotik.com/t/nordvpn-ipsec-ikev2-killswitch-for-ros6/144817/1
Thank you very much for this! I have updated my config for NordVPN and created a new one for ProtonVPN.
Here is WORKING ProtonVPN config as of 15.07.2021:
Preparation:
  1. Get recommended ProtonVPN server from here: https://account.protonvpn.com/downloads
    I have FREE account, in below steps I used “nl-free-01.protonvpn.com”.
  2. Get your Service Credentials from here: https://account.protonvpn.com/account#openvpn and use them for this setup.
  3. Import ProtonVPN CA to your router:
/certificate import file-name=ProtonVPN_ike_root.der name=“ProtonVPN CA” passphrase=“”
# Mark ALL traffic that you want to route through VPN server
/ip firewall address-list add address=192.168.88.0/24 list=under_protonvpn
/ip firewall mangle add action=mark-connection chain=prerouting src-address-list=under_protonvpn new-connection-mark=under_protonvpn passthrough=yes
# IPsec/IKEv2 configuration
/ip ipsec mode-config add connection-mark=under_protonvpn name=“ProtonVPN mode config” responder=no
/ip ipsec profile add dh-group=modp4096,modp2048,modp1024 dpd-interval=disable-dpd enc-algorithm=aes-256 hash-algorithm=sha256 name=“ProtonVPN profile”
/ip ipsec peer add address=nl-free-01.protonvpn.com exchange-mode=ike2 name=“ProtonVPN server” profile=“ProtonVPN profile”
/ip ipsec proposal add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=0s name=“ProtonVPN proposal” pfs-group=none
/ip ipsec identity add auth-method=eap certificate=“ProtonVPN CA” eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=“ProtonVPN mode config” password= peer=“ProtonVPN server” policy-template-group=ProtonVPN username=
/ip ipsec policy add dst-address=0.0.0.0/0 group=ProtonVPN proposal=“ProtonVPN proposal” src-address=0.0.0.0/0 template=yes
# In “/ip ipsec policy” you should be able to see a new dynamic rule added next to your ProtonVPN policy. It MUST exist, otherwise configuration is not working.
# (OPTIONAL) Implement a killswitch
/interface bridge add name=protonvpn_blackhole protocol-mode=none
/ip route add gateway=protonvpn_blackhole routing-mark=protonvpn_blackhole
/ip firewall mangle add chain=prerouting src-address-list=under_protonvpn action=mark-routing new-routing-mark=protonvpn_blackhole passthrough=yes
# (IMPORTANT) Exclude such VPN traffic from fasttrack
/ip firewall filter add action=accept chain=forward connection-mark=under_protonvpn place-before=[find where action=fasttrack-connection]
# Reduce MSS (should be about 1200 to 1400, but 1360 worked for me)
/ip firewall mangle add action=change-mss chain=forward new-mss=1360 passthrough=yes protocol=tcp connection-mark=under_protonvpn tcp-flags=syn tcp-mss=!0-1360
# Don’t forget to disable fasttrack rule in FIREWALL RULES and reboot Mikrotik!
This worked fine until I’ve upgraded to ROS7, not none of the traffic goes over the VPN, I’ve set the blackhole and no traffic gets blackholes either
Anyone else experiencing this ?
Check if fasttrack rule become available, you need to disable/remove it. If not - you can notify about this issue to ProtonVPN’s support.
rule is still disabled as per version 6.x
the tunnel comes up, I can ping the other side it seems routing in Version 7 is different and no traffic gets routed over the vpn tunnel
Please try to submit a ticket to Mikrotik support explaining the issue. I suppose you have a Stable version of firmware.
