I would like to know if someone here tried to configure/run ProtonVPN on Mikrotik routers.
According to ProtonVPN team it is not possible because most of Mikrotik routers support only PPTP connection protocol, which is not supported by ProtonVPN.
Have a great day!
@normis: I agree with you. I will send to ProtonVPN’s Team the link that you posted.
Normis, can you/we test to see how it works and what problems can arise, if they occur?
I’m posting the answer that I received from ProtonVPN:
We use only the highest strength encryption to protect your Internet connection. This means all your network traffic is encrypted with AES-256, key exchange is done with 4096-bit RSA, and HMAC with SHA384 is used for message authentication.
We have carefully selected our encryption cipher suites to only include ones that have Perfect Forward Secrecy. This means that your encrypted traffic cannot be captured and decrypted later if the encryption key from a subsequent session gets compromised. With each connection, we generate a new encryption key, so a key is never used for more than one session.
We use only VPN protocols which are known to be secure - IKEv2/IPSec and OpenVPN. ProtonVPN does not have any servers that support PPTP and L2TP/IPSec, even though they are less costly to operate. By using ProtonVPN, you can be confident that your VPN tunnel is protected by the most reliable protocol.
Unfortunately, Mikrotik routers do not support OpenVPN client connection, therefore, it is not possible to set up a ProtonVPN connection on it. We’re sorry for the inconveniences.
Please do not hesitate to contact us again if any additional information or assistance is needed.
Regards,
[Removed the name of the person that answered] ProtonVPN.com
Normis,
Maybe they do not know how to configure Mikrotik routers , although I doubt it.
I already sent them a message with the links that you and mrz posted as a reply to my questions.
I will test on a Mikrotik router that I have and I will write, maybe, a tutorial on how to do it.
Thank you.
mrz,
You can connect using tcp protocol, but if they use in the config file the SHA512 then it’s the same story.
However, if the SHA512 and UDP is not available in the current version of ROS and only in the v7 then in theory they are right.
Please correct me if I’m wrong.
Hello. Could you upload your config for protonvpn? With NordVpn no troubles. But with proton…even with your tricks. Trying to connect, for several seconds active peer appear and disappear with eap error
Thanks to newbean for using his code. Think it’s the same as the wiki. Not sure. If different then I may have mixed both sources up. Anyone stuck on this then drop me an IM and I’ll post the code
