Hi All
I am fairly new to mikrotik and so far I am loving it. I have successfully set up a syslog server to capture logs using the recomended manner used for proxlyizer only to run into a hurdle for proxylizer now working correctly on x_64 machines.
All workd fine apart from the IP addresses showing up in IP info as correct but as soon as I allocate to a user it shows as 127.255.255.255 and apparently it is due to the architecture.
Proxylizer support has been discontinued (Wish i knew this before i started) and no solution is in sight for me.
Does anyone know of an alternate solution to log to a syslog server and ten generate user reports. The reports i need is fairly simple, just per user domains and domains visited.
Your help will be greatly appreciated.
Bash
