All the docs on web proxy differ a bit from proxy on the routerboard 500.
Is there a seperate doc on the 500? Having trouble getting some sites to come across in complete form , for example http://www.yellowpages.com, alot of the graphic links are broken. Rule added host=www.yellowpages.com action=deny.
major screwup rule is actually allow ![]()
Anyone using Proxy on a the RB532? ![]()
I have installed the web-proxy package (confirmed in installed packages) and cannot seem to find ip>web-proxy anyware
It´s only supported over CLI, and the documentation isn´t present yet..
Regards
not “ip web-proxy” but “ip proxy”
And does cache proxy?
Web-proxy test package is intended for proxy with caching in RB500, but you have to use additional drive for caching (at CF slot), CF module or microdrive.
But using a flash module for proxy caching is not a good idea I think. It will die quickly. Using a MicroDrive should be possible, but I’ve got no idea about the possible performance of such a setup.
Perhaps some day I’ll rip the MicroDrive out of my digital camera and test this…
Best regards,
Christian Meis
Ive got a 400MB microdrive in my MT 500, still cant get it to work
