Pseudo Random Number Generator Script (Mersenne Twister)
The following script was created to produce better (pseudo) random generated numbers on a MikroTik router. The script is based on the Mersenne Twister (MT) algorithm. The script will work as written, cut-and-paste, for demonstration purposes. The script is intended to be modified for use with other scripts by either changing the “arrAdjRandNumValues” local variable to a global scope or by storing the variable’s contents to a file. The output generated from this script can be used as input to another script requiring random numbers.
The script can use either a static seed (integer) defined in the script or by default can generate a dynamic seed. The dynamic seed uses a combination of date, time and other values to seed a formula loosely based on the rand() function of the C programming language. The results are then used as the seed for the MT algorithm. The script is meant to generate positive integers. The script outputs the numbers generated to the console.
The script started out as an experiment and out of my own (obsessive) curiosity. I’ve opted not to put too much more time and effort into the script. The script has very limited usefulness since other alternatives exist. However, the script was intended to be a standalone solution. The script may prove useful under the right circumstances.
# A pseudo random number generator MikroTik script.
# Based on the Mersenne Twister pseudorandom number algorithm.
# v1.3 Tested and Developed on ROS v5.8
# Configuration Parameters
# intNumberOfRands - Number of pseudorandom number values to generate
:local intNumberOfRands 100
# intRandFloor - Lowest numeric range for generated values (must be positive value)
:local intRandFloor 0
# intRandCeiling - Highest numeric range for generated values (must be positive value)
:local intRandCeiling 100
# blnShowStats - Displays distribution for generated numbers (default false)
:local blnShowStats false
# blnOneRndPerLine - Display generated values one per line on program completions (default false)
:local blnOneRndPerLine false
# blnGenerateSeed - Use a system generated seed for value generation (default true)
:local blnGenerateSeed true
# intSeed - Static seed value above Boolean value must be false to use (default 19650218)
:local intSeed 19650218
# Remaining values are associated with system generated seed values, blnGeneratedSeed=true to use
# blnUseWiFi - Use wireless statistics as part of seed generation, experimental (default false)
:local blnUseWiFi false
# strWiFiName - Name of wireless interface, above blnUseWiFi must be true (default wlan1)
:local strWiFiName "wlan1"
# strOutFile - Temporary file used to gather wireless statistics
:local strOutFile "RndOutTraff"
# No need to modify variable beyond this line
:local arrInitValues { 0x123; 0x234; 0x345; 0x456 }
:local intInitArrayLen [ :len $arrInitValues ]
:local arrLngRandNumValues {}
:local arrAdjRandNumValues {}
:local N 624
:local M 397
:local intUpperBitMask 0x80000000
:local intLowerBitMask 0x7fffffff
:local intMatrixA 0x9908b0df
:local arrMagicValues [ :toarray ( 0, $intMatrixA ) ]
:local intProgressEvery 0
:local intPctDone 0
:local arrMerTwist {}
:local intMersTwistArrLen ( $N + 1 )
:local intTotalValues 0
:local intWiHiValue 0
:local intWiLowValue 0
:local intRandNumber 0
:local intSeenValue 0
:local arrSeenValues [ :toarray $intSeenValue ]
:put "Running..."
:for i from=( $intRandFloor ) to=( $intRandCeiling - 1 ) do={
    :set arrSeenValues ( $arrSeenValues, $intSeenValue )
:if ( $blnGenerateSeed = true ) do={
    :put "Generating seed value from system events."
    :local intUpTime [ /system resource get uptime ];
    :if ( $blnUseWiFi = true ) do={
        :put "Using wireless for seed generation."
        :local lcv 1
        :local blnContinue true
        :do {
            :put "Attempt $lcv to gather wireless traffic statistics."
            /interface monitor-traffic $strWiFiName once file=$strOutFile
            /delay 3s
            :local strInFile ($strOutFile . ".txt")
            :local strContent [/file get [/file find name=$strInFile] contents]
            :if ( [ :len $strContent ] < 1 ) do={
                :put "No content generated for wireless statistics."
            } else={
                :local intLocXmitBps ( [ :tonum [ :find $strContent \
                  "tx-bits-per-second:" 0 ] ] + 20 )
                :local intXmitBps [ :pick $strContent $intLocXmitBps ( [ :tonum \
                  [ :find $strContent "bps" $intLocXmitBps ] ] - 1 ) ]
                :local intXmitDecimalLoc [ :tonum [ :find $intXmitBps "." 0 ] ]
                :set intWiHiValue [ :tonum [ :pick $intXmitBps 0 $intXmitDecimalLoc ] ]
                :set intWiLowValue [ :tonum [ :pick $intXmitBps ( $intXmitDecimalLoc + 1 ) \
                  ( $intXmitDecimalLoc + 2 ) ] ]
                :if ( [ :len [ :tostr intWiHiValue ] ] > 0 ) do={
                    :if ( [ :len [ :tostr intWiLowValue ] ] > 0 ) do={
                        :set blnContinue false
                } else={
                    :if ( lcv > 3 ) do={
                        :set intWiHiValue 0
                        :set intWiLowValue 0
                /file remove [ /file find name=$strInFile ];
            :set lcv ( $lcv + 1 )
        } while=( $blnContinue = true )
    :local intClockValue ( [ :tonum [ :pick [ /system clock get time ] 6 8 ] ] % 6 )
    /delay 1s
    :local intCpuValue [/system resource get cpu-load ];
    :local strSysTime [ :tostr [ /system clock get time ] ]
    :local intSeconds ( ( [ :tonum [ :pick $strSysTime 0 2 ] ] ) * 3600 )
    :set intSeconds ( $intSeconds + ( ( [ :tonum [ :pick $strSysTime 3 5 ] ] ) * 60 ) )
    :set intSeconds ( $intSeconds + ( ( [ :tonum [ :pick $strSysTime 6 8 ] ] ) * ( \
      [ :tonum $intWiHiValue ] + [ :tonum $intWiLowValue ] ) ) )
    :local arrMons [ :toarray "jan,feb,mar,apr,may,jun,jul,aug,sep,oct,nov,dec" ]
    :local strDate [ :tostr [ /system clock get date ] ]
    :local intDayCount ( ( [ :tonum [ :find $arrMons \
      [ :pick $strDate 0 3 ] ] ] * 30 ) + [ :tonum [ :pick $strDate 4 6 ] ] )
    :local intYear ( ( [ :tonum [ :pick $strDate 7 [ :len $strDate ] ] ] - 2011 ) * 365 )
    :set intSeed ( ( ( ( $intYear  + $intDayCount ) * 86400 ) + $intSeconds ) + \
      [ :tonum $intClockValue ] + [ :tonum $intCpuValue ] + \
      [ :tonum $intUpTime ] + [ :tonum $intWiHiValue ] + [ :tonum $intWiLowValue ] )
    :set intSeed ( ( ( $intSeed * 1103515245 + 12345 ) / 65536) % 32768 )
    :put "Using system dynamically generated seed value: $intSeed"
 } else {
     :put "Using static seed stored in script variable with value: $intSeed"
     :put "Numbers will be testable and repeatable (deterministic)."
# End of creating seed
# $arrMerTwist[N] is array for the state vector
:put "Step 1: Initializing (seeding) array for state vector."
:set arrMerTwist [ :toarray ( [ :tonum $intSeed ] & 0xffffffff ) ]
:set intTotalValues ( $N - 1 )
:set intProgressEvery ( $intTotalValues / 20 )
:set intPctDone 0
# if ( $intMersTwistArrLen = N+1 ) means arrMerTwist[N] is not initialized */
:set intMersTwistArrLen ( $N + 1 )
:for lcv from=1 to=( $N - 1 ) do={
    :if ( ( $lcv % $intProgressEvery ) = 0 ) do={
        :set intPctDone ( $intPctDone + 5 )
        :put "Step 1: $intPctDone% completed."
    :local intValue1 [ :tonum [ :pick $arrMerTwist ( $lcv - 1 ) ] ]
    :set intValue1 ( $intValue1 ^ ( $intValue1 >> 30 ) )
    :set intValue1 ( $intValue1 * 1812433253 )
    :set intValue1 ( $intValue1 + $lcv )
    :set intValue1 ( $intValue1 & 0xffffffff )
    :set arrMerTwist [ :toarray ( [ :pick $arrMerTwist 0 $lcv ], $intValue1 ) ]
    :set intMersTwistArrLen [ :tonum $lcv ]
:set intMersTwistArrLen ( $intMersTwistArrLen + 1 )
:put "Step 2: Starting initialization by array"
:local i 1
:local j 0
:local k [ :tonum $intInitArrayLen ]
:if ( $N > $intInitArrayLen ) do={
    :set k [ :tonum $N ]
:local intTotalValues ( [ :tonum $k ] - 1 )
:set intPctDone 0
:while ( $k > 0 ) do={
    :if ( ( $k % $intProgressEvery ) = 0 ) do={
        :put "Step 2: $intPctDone% completed."
    :local intValue1 [ :tonum [ :pick $arrMerTwist ( $i - 1 ) ] ]
    :set intValue1 ( $intValue1 * 1664525 )
    :set intValue1 ( ( [ :tonum [ :pick $arrMerTwist $i ] ] ) ^ $intValue1 )
    :set intValue1 ( $intValue1 + ( [ :tonum [ :pick $arrInitValues $j ] ] ) )
    :set intValue1 ( $intValue1 + [ :tonum $j ] )
    :set arrMerTwist [ :toarray ( [ :pick $arrMerTwist 0 $i ], $intValue1, \
      [ :pick $arrMerTwist ( $i + 1 ) [ :len $arrMerTwist ] ] ) ]
    :set i ( $i + 1 )
    :set j ( $j + 1 )
    :if ( $i >= $N ) do={
        :set arrMerTwist [ :toarray ( [ :pick $arrMerTwist ( $N - 1 ) ], \
          [ :pick $arrMerTwist 1 [ :len $arrMerTwist ] ] ) ]
        :set i 1
    :if ( $j >= $intInitArrayLen ) do={
        :set j 0
    :set k ( $k - 1 )
:put "Step 3: Last portion of initialization by array."
:set k ( $N - 1 )
:set intTotalValues $k
:set intPctDone 0
        :put "Step 3: $intPctDone% completed."
    :set intValue1 ( $intValue1 * 1566083941 )
    :set intValue1 ( $intValue1 - $i )
    :set i ( $i + 1 )
        :set  i 1
    :set k ( $k - 1 )
# MSB is 1; assuring non-zero initial array
:set arrMerTwist [ :toarray ( [ :tonum 0x80000000 ], [ :pick $arrMerTwist 1 \
  [ :len $arrMerTwist]  ] ) ]
:put "Initialization completed."
# Main Program generate pseudorandom numbers
:put "Starting number generation."
:local intRandNumVal 0
:for i from=0 to=( $intNumberOfRands - 1 ) do={
    :put ("Generating random number " . ( $i + 1 ) . " of $intNumberOfRands.")
    :if ( $intMersTwistArrLen >= $N ) do={
        :if ( $intMersTwistArrLen = ( $N + 1 ) ) do={
            :put "** ERROR state vector array is uninitalized. **"
            :error "Unrecoverable error program terminiated."
        :local intValue1 0
        :local intValue2 0
        :local kk 0
        :set intTotalValues ( $N - $M )
        :set intPctDone 0
        :while ( $kk < ( $N - $M ) ) do={
            :if ( ( $kk % $intProgressEvery ) = 0 ) do={
                :put "Main Program sub task A: $intPctDone% completed."
            :set intValue1 [ :tonum [ :pick $arrMerTwist $kk ] ]
            :set intValue2 [ :tonum [ :pick $arrMerTwist ( $kk + 1 ) ] ]
            :set intRandNumVal [ :tonum ( ( $intValue1 & $intUpperBitMask ) | \
              ( $intValue2 & $intLowerBitMask ) ) ]
            :set intValue1 ( [ :tonum $intRandNumVal ] & 1 )
            :set intValue1 [ :tonum [ :pick $arrMagicValues $intValue1 ] ]
            :set intValue2 [ :tonum [ :pick $arrMerTwist ( $kk + $M ) ] ]
            :set intValue1 [ :tonum ( ( $intValue2 ^ ( $intRandNumVal >> 1 ) ) ^ $intValue1 ) ]
            :if ( $kk < 1 ) do={
                :set arrMerTwist ( $intValue1, [ :pick $arrMerTwist 1 [ :len $arrMerTwist ] ] )
            } else={
                :set arrMerTwist ( [ :pick $arrMerTwist 0 $kk ], $intValue1, \
                  [ :pick $arrMerTwist ( $kk + 1 ) [ :len $arrMerTwist ] ] )
            :set kk ( $kk + 1 )
        :set intPctDone 0
        :while ( $kk < ( $N - 1 ) ) do={
                :put "Main Program sub task B: $intPctDone% completed."
            :set intValue2 [ :tonum [ :pick $arrMerTwist ( $kk + ( $M - $N ) ) ] ]
            } else={
            :set kk ( $kk + 1 )
        :set intValue1 [ :tonum [ :pick $arrMerTwist ( $N - 1 ) ] ]
        :set intValue2 [ :tonum [ :pick $arrMerTwist 0 ] ]
        :set intValue2 [ :tonum [ :pick $arrMerTwist ( $M - 1 ) ] ]
# Next line is for saftey, but ($N - 1) should never be < 1
        :if ( ( $N - 1 ) < 1 ) do={
        } else={
            :set arrMerTwist ( [ :pick $arrMerTwist 0 ( $N - 1 ) ], $intValue1, \
              [ :pick $arrMerTwist [ :tonum $N ] [ :len $arrMerTwist ] ] )
        :set intMersTwistArrLen 0
    :set intRandNumVal [ :tonum [ :pick $arrMerTwist $intMersTwistArrLen ] ]
# Tempering
    :set intRandNumVal [ :tonum ( $intRandNumVal ^ ( $intRandNumVal >> 11 ) ) ]
    :set intRandNumVal [ :tonum ( $intRandNumVal ^ ( ( [ :tonum $intRandNumVal ] << 7 ) \
      & 0x9d2c5680 ) ) ]
    :set intRandNumVal [ :tonum ( $intRandNumVal ^ ( ( [ :tonum $intRandNumVal ] << 15 ) \
      & 0xefc60000 ) ) ]
    :set intRandNumVal [ :tonum ( $intRandNumVal ^ ( [ :tonum $intRandNumVal ] >> 18 ) ) ]
# end genrand_int32
    :set arrLngRandNumValues ( $arrLngRandNumValues, $intRandNumVal )
# Some Error checking
    :if ( ( [ :len [ :tostr $intRandNumVal ] ] < 1 ) or ( [ :tonum $intRandNumVal ] = 0 ) ) \
      do={
        :put "** DIAGNOSTICS **"
        :put ("intRandNumVal($intRandNumVal) intMersTwistArrLen($intMersTwistArrLen) \
          intSeed($intSeed) len_mt(" . [ :len $arrMerTwist ] . ")")
        :put "Contents of \$arrMerTwist array:"
        :put $arrMerTwist
        :error "** ERROR ** Program execution halted no \$intRandNumVal value generated"
# Done with error checking and diagnostic reporting
    :set intRandNumber ( ( $intRandNumVal % ( $intRandCeiling - $intRandFloor + 1 ) ) \
      + $intRandFloor )
    :set arrAdjRandNumValues ( $arrAdjRandNumValues, $intRandNumber )
    :set intSeenValue [ :tonum [ :pick $arrSeenValues ( $intRandNumber - $intRandFloor ) ] ]
    :set intSeenValue ( $intSeenValue + 1 )
    :if ( ( $intRandNumber - $intRandFloor ) = 0 ) do={
        :set arrSeenValues [ :toarray ( [ :tonum $intSeenValue ], [ :pick $arrSeenValues 1 \
          [ :len $arrSeenValues ] ] ) ]
    } else={
        :set arrSeenValues [ :toarray ( [ :pick $arrSeenValues 0 \
          ( $intRandNumber - $intRandFloor ) ], [ :tonum $intSeenValue ], \
          [ :pick $arrSeenValues ( ( $intRandNumber - $intRandFloor ) + 1 ) \
#    :put "Generated raw random number is $intRandNumVal"
#    :put "Adjusted random value is: $intRandNumber"
:if ( $blnShowStats = true ) do={
        :put "Used dyamically generated seed value: $intSeed"
    } else={
        :put "Used static seed based on script \$intSeed value: $intSeed"
    :put "Distribution of Numbers Generated [ #/Occurence ]"
    :local intTotalRandsGen 0
    :for i from=0 to=( [ :len $arrSeenValues ] - 1 ) do={
        :local intSeenCount [ :tonum [ :pick $arrSeenValues $i ] ]
        :set intTotalRandsGen ( $intTotalRandsGen + $intSeenCount )
        :set intRandNumber ( $i + $intRandFloor )
        :local strOutLine ( $intRandNumber . "/" . $intSeenCount )
        :for j from=1 to=( 16 - [ :len [ :tostr $strOutLine ] ] ) do={
            :set strOutLine " $strOutLine"
        :set strOutLine "[$strOutLine] "
        :local intDrawToCol [ :tonum $intSeenCount ]
        :if ( $intDrawToCol > 62 ) do={
            :set intDrawToCol 62
        :set j 1
        :while ( $j <= $intDrawToCol ) do={
            :set strOutLine [ :tostr ( $strOutLine . "*" ) ]
            :set j ( $j + 1 )
        :put "$strOutLine"
    :put "Total random numbers generated: $intTotalRandsGen"
:if ( $blnOneRndPerLine = true ) do={
    :foreach intRndValue in=( $arrAdjRandNumValues ) do={
        :put $intRndValue
} else={
#    :put $arrLngRandNumValues
    :put $arrAdjRandNumValues
:put "Done."
Thanks for that!
To make it compatible with 6.37.1 I just had to replace the empty array declaration {} with “”
Working with ROS 6.45.3.
Just some minor edits of syntax was required.
Big thanks to Tealfrog for the original code :slight_smile:
              :local arrLngRandNumValues ""
              :local arrAdjRandNumValues ""
              :local N 624
              :local M 397
              :local intPctDone 0
              :local arrMerTwist ""
              :put "Running..."
                      :local lcv 1
                      :do {
                          /delay 3s
                          } else={
                              } else={
                                      :set intWiHiValue 0
                  /delay 1s
               } else={
              :set intPctDone 0
              :local i 1
              :local j 0
              :set intPctDone 0
                  :set i ( $i + 1 )
                  :set j ( $j + 1 )
                      :set i 1
                      :set j 0
                  :set k ( $k - 1 )
              :set k ( $N - 1 )
              :set intPctDone 0
                  :set i ( $i + 1 )
                      :set  i 1
                  :set k ( $k - 1 )
                      :local intValue1 0
                      :local intValue2 0
                      :local kk 0
                      :set intPctDone 0
                          } else={
                          :set kk ( $kk + 1 )
                      :set intPctDone 0
                          } else={
                          :set kk ( $kk + 1 )
                      } else={
              # Tempering
                    & 0x9d2c5680 ) ) ]
                    & 0xefc60000 ) ) ]
              # end genrand_int32
                    do={
                      :put $arrMerTwist
                    + $intRandFloor )
                  } else={
                  } else={
                      :set j 1
                          :set j ( $j + 1 )
                      :put "$strOutLine"
                      :put $intRndValue
              } else={
              :put "Done."
Ps if anyone knows or can figure out how to get rid of the leading semi colon from the $arrAdjRandNumValues variable you would be a godsend!!
I change this code to function $FuncRandom with tree parameter intNumberOfRands intRandFloor intRandCeiling . Return from $FuncRandom is array. At the end I add examples how use it in any places of your final script.
local FuncRandom  do={
:local intNumberOfRands $1
:local intRandFloor $2
:local intRandCeiling $3
:local N 624
:local M 397
:local intPctDone 0
:put "Running..."
        :local lcv 1
        :do {
            /delay 3s
            } else={
                } else={
                        :set intWiHiValue 0
    /delay 1s
 } else={
:set intPctDone 0
:local i 1
:local j 0
:set intPctDone 0
    :set i ( $i + 1 )
    :set j ( $j + 1 )
        :set i 1
        :set j 0
    :set k ( $k - 1 )
:set k ( $N - 1 )
:set intPctDone 0
    :set i ( $i + 1 )
        :set  i 1
    :set k ( $k - 1 )
        :local intValue1 0
        :local intValue2 0
        :local kk 0
        :set intPctDone 0
            } else={
            :set kk ( $kk + 1 )
        :set intPctDone 0
            } else={
            :set kk ( $kk + 1 )
        } else={
# Tempering
      & 0x9d2c5680 ) ) ]
      & 0xefc60000 ) ) ]
# end genrand_int32
      do={
        :put $arrMerTwist
      + $intRandFloor )
    } else={
    } else={
        :set j 1
            :set j ( $j + 1 )
        :put "$strOutLine"
        :put $intRndValue
} else={
    #:put "aa $arrLngRandNumValues"
    :return $arrAdjRandNumValues
# Your script.....
# Your script.....
# Run function with Numbers Min Max, examples
put [$FuncRandom "2" "44" "50" ];
#put ("Random 3x numbers in range 50-60 but display second result :".[$FuncRandom 3 50 60]->2)
#local SaveResults [$FuncRandom 1 0 100]
# Your script.....
# Your script.....
Alternalive.
I try and found and parse one of WebAPI to receive random number from any range I wont online. No consume CPU like upper one..
Example: one number, random from range 44..120. More at https://www.random.org/clients/http/
put ([/tool fetch mode=https http-method=get url="https://www.random.org/integers/\?num=1&min=44&max=120&col=1&base=10&format=plain&rnd=new" as-value output=user ]->"data")
91
Someone proposed to replace
with
for array declaration.
Both is wrong... you should use
[ :toarray "" ]
for empty array declaration. (see: How to define empty array)
Not tested, but I guess that could fix your issue.
I wont pretend to know what either of you are really talking about. I’m a fully qualified noob on scripting, ie good enough to cut, paste and hack away at code to make it do what i need.
All i was chasing was a random number in some global variable.
Anyway I’ve found another solution which was someone else’s script I’ve modified. (sorry can’t find it now to give credit)
:local Sum 0
:foreach Interface in=[ /interface find ] do={
  :set Sum ($Sum + [ /interface get $Interface tx-byte ])
:global random [:pick $Sum ([:len $Sum]-2) [:len $Sum]]
:set $random [:tonum $random]
:put $random
How about Perlin Noise?
The GLSL for a simplified noise based on Perlin would be
float rand(float n){return fract(sin(n) * 43758.5453123);}
Obviously we don’t have sin so we would need to take an approximation from somewhere. What about Bhaskara I’s sine approximation formula?
https://en.wikipedia.org/wiki/Bhaskara_I’s_sine_approximation_formula
Fract just returns the fractional part of the value.
So
float sin(float a){return (4 * a * (180 - a)) / (40500 - (x * (180 - x)));}
float rand(float n){return (sin(n) * 43758.5453123)%1;}
Or
sin = (4 * n * (180 - n)) / (40500 - (n * (180 - n)))
return (sin * 43758.5453123)%1;
Major snag here: This is designed to give us a normalised value between 0 (inclusive) and 1 (exclusive).
That’s OK though, because RouterOS uses 64bit signed ints. So we can just shunt the decimal point 7 places to the right. And do some other tinkering to make sure we have numbers big enough. (I’ve just taken a hammer to a screw here, rather than figuring out exact numbers…)
:global rndPos ($rndPos + 1)
:local sin ((40000 * $rndPos * (180 - $rndPos)) / (40500 - ($rndPos * (180 - $rndPos))))
:local temp (($sin * 437585453123) % 1000000)
:if ($temp < 0) do={:put ($temp * -1)}
:if ($temp >= 0) do={:put ($temp)}
This should give you a sequence of pseudo-random numbers between 0 (inclusive) and 1000000 (exclusive). Just use modulo again to cut it down to whatever range you need.
I’m not sure where it wraps, this is back-of-a-fag-packet stuff. Someone with a better head for numbers could probably make it “proper”. Also it’s 2am and I had 5 hours sleep last night.
You can tweak the magic number, 437585453123
It might be possible to put in a feedback loop so that the output becomes (or influences) the next magic number, which would increase the range - but it’s necessary to make sure that it doesn’t get too small. (As an extreme example, if the output was 157689724000000000001 then the new magic number would come out as 1 if you just used modulo to pull the last 12 digits.)
Use Certificate generator to make your random number.
http://forum.mikrotik.com/t/one-line-password-generation-without-fetch-tool/141623/1
Script here:
http://forum.mikrotik.com/t/one-line-password-generation-without-fetch-tool/141623/11
Neat, thanks! I suppose that could be adapted to derive a number from the generated password - just by using the hex conversion and multiplying up before adding the next value. A lot of it would go away if you just want a 64bit random number.
:local hexSrc ([/certificate scep-server otp generate minutes-valid=0 as-value]->"password")
:for i from=1 to=16 step=2 do={
  :set $hex "0x$[:pick $hexSrc $i ($i+2)]"
  :set $num ($num*256 + $hex)
:put ($num)
Then again use mod to get a number in a specific range.
This will generate a lot of random things.
http://forum.mikrotik.com/t/password-pin-and-and-hash/144676/7
Awesome, thanks
My need was just for a number - which is how I came across this post, and not the others.
I write my own version:
Random number between 0 and 99 or string between 00 and 99
http://forum.mikrotik.com/t/random-number-between-0-and-99-or-string-between-00-and-99/149267/1
@Sob …. MikroTik are memory misers because the value proposition is tied to lowest cost providing best possible functionality …. So to add a function library would require adding more memory …. In mfg for every cent in additional cost requires a 400% return …. So it’s understandable that tradeoffs must be made …. In the CPE industry the buyer (I.e. ISPs) strives for the lowest cost possible
As a techie I want far more memory because that will provide much more functionality…. Like for example a function library that does not limite file size processing would be nice …. Versus the kluge like chucking etc etc etc. :slight_smile:
All of that is true, but it goes further than you say. We’ve got people griping about how the brandest newest features (e.g. ZeroTier) aren’t supported on ancient MIPS CPUs and at the same time griping about how ROS 7 isn’t “finished” yet because it isn’t 100% feature-for-feature identical to ROS 6.
But heaven forfend they deprecate something so horribly broken it shouldn’t be used any more like PPTP or telnet. You threaten that, and you get people crawling out to defend it with their very Internet lives.
How is MikroTik supposed to navigate between Scylla and Charybdis? You can’t have infinite new features on fixed-memory hardware from arbitrarily far in the past.
To return to the topic, I like the solution up-thread to pull the data from random.org. Delegate the hard work of providing arbitrary PRNGs to someone else’s hardware.
On this particular topic, they did add “:rndnum” in V7:
:put [:rndnum from=1 to=1000]
149
See a more colorful example here: http://forum.mikrotik.com/t/how-to-add-color-to-output/142687/1
They did add a [:timestamp] too in V7, but (2*$new-functions / 4*years)~(“nothing”|“nil”).
Hmm, how did I miss this…
Any documentation on this? I did not find any.
Generate mac
:put [:rndstr length=12 from="0123456789abcdef"]
I use the CLI and the “tab completion”, which is how I found it last year in one of the betas. But seem documented now:
https://help.mikrotik.com/docs/display/ROS/Scripting#Scripting-Globalcommands
Manual has an error in the example for rndstr
:put [:> rndnum > from=“abcdef%^&” length=33];
should be
:put [:> rndstr > from=“abcdef%^&” length=33]
Also do not need the ; at end of each line in manual as well. Its only needed to separate multiple command on same line.
Nice that Mikrotik got it now. My script could produce a lot and has even a help function to explain the different options.
http://forum.mikrotik.com/t/password-pin-and-and-hash/144676/1
I wrapped random.org approach into a function, [$RNDORGINT min= max= base=] so to cover all the bases :wink:.
# based on https://www.random.org/clients/http/
# from comment here http://forum.mikrotik.com/t/pseudo-random-number-generator-script-mersenne-twister/51962/1
:global RNDORGINT
:set RNDORGINT do={
    # params
    :local lmin [:tonum $min]
    :local lmax [:tonum $max]
    :local lbase [:tonum $base]
    # consts
    :local lnum 1
    :local lformat "plain"
    :local lcol "1"
    :local lrnd "new"
    # defaults
    :if ([:typeof $lmin]!="num") do={:set lmin 0}
    :if ([:typeof $lmax]!="num") do={:set lmax 1000}
    :if ([:typeof $lbase]!="num" ) do={:set lbase 10}
    :if (!([:tostr $lbase]~("2|8|10|16"))) do={:error "Base must be 2, 8, 10, or 16"}
    # setup url
    :local url "https://www.random.org/integers/?"
    :set url "$($url)min=$lmin&max=$lmax&base=$lbase"
    :set url "$($url)&num=$lnum&col=$lcol&format=$lformat&rnd=$lrnd"
    :local headers "Content-Type: text/plain"
    # now get number from random.org using fetch
    :local resp [/tool fetch url=$url http-header-field=$headers output=user as-value]
    :local rndasstr ($resp->"data")
    # return it as string
    :return $rndasstr
The function can be used like so:
# Note: $RNDORGINT returns a string at present, (:typeof [$RNDORGINT])="str"
# default is min=1 max=1000 base=10
:put [$RNDORGINT].
# 449
:put [$RNDORGINT min=1 max=2]
# 1
:put [$RNDORGINT min=1000 max=9999]
# 4803
# base can be 2, 8, 10, or 16
:put [$RNDORGINT min=1000 max=9999 base=2]
00101011000011
# negative numbers
:put [$RNDORGINT min=-10 max=0]
# -3
