PTP-tunnel
I purchased a couple of the HEXs for a project we are working on.
Site1 is static IP, publicly accessible, has ip router (our connection to the WAN).
Site2 is StarLink connected
The goal is to get bi-directional communication across the link.
I'm just not really sure where to start with this. Whether the HEXs should be a bridge or a router. I'm thinking router at least on the Site2, then maybe a bridge on Site1?
Figured on using WireGuard tunnel, but it doesn't need to be. Can be anything that tunnels. Prefer to take a VLAN from Site1 and put it at Site2, meaning we have a VLAN26 that is our management network at Site1 and would like to put VLAN26 at the remote Site2.
This seems like something simple, so I hope someone can help.
If you want an L2 across multiple sites, look into l2tp. Having said that, there is no reason that they have to be on the same LAN. Routing is a better solution in the end, but that will require more setup for routing protocols and whatnot.
