PTPP
Hi
I am struggling with Configuring the following:
I have PTPP Client that connects to the PTPP Server. I would Like to route all the Pc behind the router though this client.
Current config
Interface 1 - Dsl IP 172.1.0.1
PTPP-OUT - Connected 10.2.4.XX - Gateway 10.2.4.203.
Interface 3 - 10.35.0.0/24 - Want to use to give DHCP to Local network.
I can ping Pc on the other side if i use the PTPP-OUT interface to ping. But it won’t work from any other interface. How can i get it to work on interface 3?
Regards,
I think, you need setup routes correctly…
