Use WDS station for the client and WDS dynamic on the Ap or you have to run NAT on the station interface which would make difficult to use a public IP behind it
I got /24 from my ISP. And my ISP already routed to my core router.
But my topolgy is:
Internet (isprouter)-------- My Core Router ------ RBXX1 ))))) (((((( RBXX2 ------- PC client
My question is what setting should I make for RBXX1 ))))) (((((( RBXX2 ?
RBXX1 as AP Bridge, right ?
RBXX2 as Station, right ?
And how to configure routing beetwen ether1 & wlan1 in RBXX2 ?
Isn’t the point of a public Ip to be reachable? If you are worried about security why not use a private IP. But if you want a public I would bridge your interfaces eth1-BR-wlan1-AP-BRIDGE ---- WDS-STATION-wlan1-BR-eth1 then just configure the Public IP on the device connected to the eth1 of the station
