Public IP through PPPoE
I wanna pass PUBLIC IP through PPPoE.
Where after login user get an PUBLIC IP and connect to INTERNET through that IP address.
Rafiq…
You can assing public network to the local interface, when public IP addresses will be assigned to the users.
Another option to use FULL-NAT and translate public IP addresses for the specific clients.
Hi
You can request a range of public IP’s from your ISP, and request from them to route that subnet towards your WAN IP, so in that case you can use variety of solutions, as Sergejs mentionet configure LAN interface, use DST-NAT, also use that range to create a public pool for pppoe and alocate public IP’s to your pppoe clients. But in all cases make sure that public subnet doesn’t match in any NAT rules that you have previous configured, like NAT everything out WAN interface.
Regards.
Faton :slight_smile:
Dear
What will be the local address of my profile?
And according to local address what will be the route for public IP?
As example I assigned local address 192.168.100.15 and remote address comes from the pool [where pool defined from 192.168.100.16-192.168.100.30.
And the default gateway is 192.168.100.1.
How the operations will be success.
Please note that all private IP will be converted to public IP
rafiq…
H(a)i,
use Proxy-ARP.
Rafiq, give mor:)e details about the configuration scenario you have selected.
NAT, routing ?
Local-address is the address of the router from the private PPP server interface.
P.S.
Another method to achieve requested scenarion,
use ‘arp-reply’ and split the existing local subnet for public and local interfaces.
I am running PPPoE server in my network with private IP. I wanna pass public IP through it.
What will be configuration for passing public IP thorough that server?
Like I got 202.148.56.XX/25 from my ISP and want to assign public IP to some of my client using that PPPoE server.
Please give me detailes for this scenario.
you can add bridge interface. Then run pppoe server on this interface.
Make pool with public ips and create the profiles
Maxi
No need to make a bridge. If you are running nat on the same box, just add the pool of public IP’s On the PPP profile the local address will be the current public address on the outside of your nat.
assigne dst-nat and got ping to profile local address. But can’t ping to beyond Mikrotik.
There is a default route for ordinary PPPoE user.
Rafiq…
Add IP pool of you public IPs.
Make profile with a public IP in the local address field.
Add a route of the whole network [that you added in IP pool]. For example
IP ADDRESS GATEWAY INTERFACE
X.X.X.X/X X.X.X.X Wan
Gateway will be
the next hope of your
current pppoe server
Now add another route at your next hope of your pppoe server as
X.X.X.X/X X.X.X.X Lan
IP is the Wan int. IP
of PPPoE server
rafiq…
sorry I left out the details :sunglasses:
