Is there a list of all devices compatible with PW48V-12V85W power supply?
At this moment, I need to know specifically about these devices:
CRS328-4C-20S-4S+RM
CRS317-1G-16S+RM
CRS312-4C+8XG-RM
CRS328-4C-20S-4S+RM
CRS317-1G-16S+RM
CRS312-4C+8XG-RM
On this page (third party):
https://www.getic.com/product/psu-open-frame-12v-7a-for-ccr-r2
the compatible models are listed as:
CCR1016-12G
CCR1036-12G-4S
CCR1036-12G-4S-EM
CCR1036-8G-2S+
CCR1036-8G-2S+EM
CCR1016-12S-1S+
CRS326-24S+2Q+RM
CCR2004-1G-12S+2XS
CCR2116-12G-4S+
but cannot say if the source is reliable.
The CRS328 seemingly wants 24V, see:
http://forum.mikrotik.com/t/solved-crs328-4c-20s-1s-crs317-1g-16s-internal-voltage/123213/1
As well the CRS317-1G-16S+RM has dual power supplies 24V 2.5A:
https://www.mikrotik-store.eu/en/mikrotik-24v2apow-replacement-power-supply?language=en
The CRS312-4C+8XG-RM seems to be instead powered (as well dual) at 12V 5A:
https://www.roc-noc.com/mikrotik/routerboard/ps/GB60A-S12.html
so it could be compatible, the size has to be checked, judging from this:
https://www.ispsupplies.ca/SSP%20Applications/NetSuite%20Inc.%20-%20SCA%20Vinson/Development/product_images/images/MikroTik-RouterBOARD-PW48-12V85W.02.jpg
the -48V power supply is longer and has more spaced mounting holes, it has also to be seen if there are already the “other” threaded supports on the case (or you will need to drill two holes).
