I just want to get two of them i was surprised when the MikroTik staff on MUM in USA said that can communities each other via ELECTRICITY.
Can i get more information how esaclu it works or if you have web link where can i get more information abouth that will be appreciate
The device is not yet for sale. More information will be coming in a few months.
mkx
May 3, 2018, 1:06pm
3
I can only guess, but my guess is that it will be using power-line communication standard for one of it’s interfaces. If done correctly, it will be compatible to other similar products to mix in same network.
Trisc
May 4, 2018, 8:45am
4
Normis, will it have interchangeable plugs - 2 pin, 3 pin European/UK/US etc?
Wyz4k
May 22, 2018, 2:05am
5
I also hope this has interchangeable plugs.
normis
May 22, 2018, 11:16am
6
No, but there will be different models for different regions.
Hi, do you know what wireless specs will this device have? How many chains on which bands?
Hi all,
Any news when these will be available?
Any update on this, Normis? Looking forward to this device!
And… ‘a few Months’ have passed already now…
hutsch
September 8, 2018, 1:57pm
10
… another month passed and no news on this “PWR-Line AP”.
Hey Mikrotik staff. C’mon, post some news!
Hutsch
2.4Ghz b/g/n, dual chain. See https://fccid.io/TV7PL64112ND
Simono
October 24, 2018, 4:47pm
12
When this device will be possible to buy?
ntblade
October 31, 2018, 5:10pm
13
Any availability update please?
Well, it would make sense if it would use G.hn for power-line communications and 5 GHz WiFi. So you could place one in each room and not having too much interference, especially when the device will have low gain antennas (less disturbance from other WiFi signals).
It would also be nice to have a power supply (24V/48V DC) with builtin power-line communications bridge. So to connect any MT device (Router, Switch, AP, …) to this network. It would have two connectors: DC out and Ethernet. Just swap the orginal power supply against this new one and connect the additional LAN port to your MT device.
mkx
November 5, 2018, 4:26pm
16
Single connector - ethernet. And have selectable PoE: either 48V 802.3af or 24V passive …
ntblade
November 5, 2018, 4:30pm
17
The recent posts seem like feature requests but still no news if these actually exist!
Pea
November 30, 2018, 11:35pm
18
According to this shop PL7411-2nD will come 12.12.2018:
https://www.wifihw.cz/default.asp?cls=stoitem&stiid=4329
Product code: PL7411-2nD
CPU: QCA9533
CPU: nominal frequency 650 MHz
PLC chipset: AR7420
Size of RAM: 64 MB
Memory: 16 MB Flash
10/100 Ethernet ports: 1
Wireless Built-in: 2.4 GHz 802.11b/g/n, dual-chain
Antenna gain: 1.5 dBi
Antenna beam width: 360°
Wireless chip model: QCA9533
Supported input voltage: 100 V - 240 V
Dimensions: 50 x 68 x 33mm
Operating temperature: -20°C .. +60°C
ROS license level: 4
Operating system: RouterOS
Max power consumption: 7 W
Power plug type: EU type (C)
Simono
December 3, 2018, 4:11pm
20
Waiting for devices with Power Line from Mikrotik.
