Has anyone tried set up qos for geforce now service ?
bump!
Will work like any other QoS, if you don’t know what ports (likely udp) you will need to use torch to identify them, mangle and simple queue tree. Job done.
It seems simple said like this…
I’m very basic about mangle and queue. If it doesn’t bother you, can you give a practical example of how to configure it with the UI? Thank you ![]()
