Good day…
Ive been doing some perusal around the forums and have yet to find an “answer” really to how many clients one could have running off an sr9 access point ( in a wisp situation) and also if the cards are suitable for stable browsing and voip…
ps. the planned area is interference free… so the spec. scanner says. Surprised Surprised hehe.
any info would be appreciated.
Regards…
60 concurrent connections should not be a problem!
Voip is not very bandwidth intensive, depends on codec used. My sip is running on average 11kbps up and 11kbps down!
I hope this will help you!
Regards
Mr G
Thanks much for the info… reason why I asked is because packets tend to have a mind of their own in the 900mhz band…
Also, what type of range would a sr9 connected to a 14dbi sector yeild ( under ideal conditions) … a supposition would be fine.
Regards…
