hi I would like I do not know if I am in the right topic in case I apologize in advance. I would like to ask for information I have a private device proxy and I would like all my devices to automatically connect to the private proxy from the mikrotik router without having to enter the proxy authentication and password. is it possible to configure a proxy as a client without having to use the web browser settings? but have the proxy ip directly?
Transparent proxy might be what you are looking for (e.g. use proxy for selected traffic without specifying it at the client)
After you setup the proxy , redirect all passing traffic that should be proxied to the proxy port.
Here the MT has IP address 192.168.87.1 and all port 80 traffic should be proxied except that from or to the MT router.
“!” means NOT
# create proxy with the features you like
/ip proxy
set enabled=yes max-cache-size=3000KiB parent-proxy=0.0.0.0
# now redirect traffic with dst-port=80 via proxy port 8080, exclude router traffic
add action=redirect chain=dstnat comment="transparent proxy" dst-address=!192.168.87.1 dst-port=80 protocol=tcp src-address=!192.168.87.1 to-ports=8080
A word of warning: https (TCP port 443) can not be transparently proxied because it is almost certain that proxy won’t have the right certificate installed.
Yup.
This will not give you much, since most sites today uses 443
Explicit proxy will work, as device will send a “CONNECT” request through the Proxy tunnel. But caching of pages is not possible as the encryption changes with every download.
https://stackoverflow.com/questions/516323/https-connections-over-proxy-servers
Auto detection/configuration based on WPAD or PAC file. Might be another way if the client device supports this. (https://en.wikipedia.org/wiki/Web_Proxy_Auto-Discovery_Protocol)
