I have a external proxy, and it works both http and https through the proxy. Now i want to do transparent proxy, so i set it as MT’s parent proxy, but only http can work, the https can not work. Any ideas? I also find this thread, seems the same problem, is it not fixed yet?
chain=dstnat action=redirect to-ports=8080 protocol=tcp src-address=192.168.88.0/24 dst-port=80 log=no log-prefix=""
chain=dstnat action=redirect to-ports=8080 protocol=tcp src-address=192.168.88.0/24 dst-port=443 log=no log-prefix=""
ip proxy print
enabled: yes
src-address: ::
port: 8080
anonymous: no
parent-proxy: xxx.xxx.xxx.xxx
parent-proxy-port:yyyyy
cache-administrator: webmaster
max-cache-size: unlimited
max-cache-object-size: 2048KiB
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
cache-path: disk1/web-proxy
