i’m having a hard time understanding this line in 7.15 changelog
*) wireguard - added option to mark peer as responder only;
and the relative documentation
is-responder (yes | no; Default: no)
Specifies if peer is intended to be connection initiator or only responder. Should be used on WireGuard devices that are used as “servers” for other devices as clients to connect to. Otherwise router will all repeatedly try to connect “endpoint-address” or “current-endpoint-address” causing unnecessary system logs to be written.
should i use it for site2site peers or for roadwarrior ones?
You should use this for the device which acts as initiator of the connection.
Not if some device is only waiting for connections to come in (useless there).
So roadwarrior situation:
The mobile device should have it. The “server” not (yeah yeah, wireguard is all peers, I know …)
Site 2 site: can be both if both have a fixed IP.
If only one has a fixed IP, it should be used on the site with dynamic IP.
if that is the case the utility is lost to me:
wouldn’t i want something that flags on the “server” a specific peer as “you should not try to reach this one, it will always be it that contacts you” to avoid spamming packets to a non existent endpoint?
or am i misinterpreting this?
Not required at all unless using BTH, which should only be used if both ends do not have a public IP or the ISP router cannot forward ports to the MT device.
Otherwise advise avoiding all that nonsense.
Shot myself in the foot by using it on the “server” side in a router-router-VPN scanario.
Result was that new packets form the “client/caller” passed flawlessly, so I could reach other services in my home lab but new packets from the “server/responder” were dropped! Not what I expected but in a very close definition of being a responder quite obvious… LOL
Not required for standard setups as stated and its redundant anyway. Its basic understanding of how wireguard works → A peer client at handshake initiates the connection, the peer Server responds.
Why would the admin need to tell himself anything extra, he knows the config already. Its confusing and I see no point to it.
Its strictly a BTH function when there is no clear client server relationship as the connection is done at the MT cloud.
Tried to setup mikrotik wireguard in a site-to-site manner, whereas one side is having CGNAT and is the connection initiator (client side, B).
The other server side (side A) site has a bridged WAN fixed public IPv4 and is set as a responder, without the endpoint/port set nor persistent keep-alive being set.
Now, I didn’t manage to set things up fully working, likely due to some other rules bugging me that I will need to trobubleshoot further or CGNAT might be preventing tunnel establishment.
Either way, I noticed side A is trying to initiate the connection regardless of the fact that it is checked off as a responder (in 7.16.1).
Likely a bug to report, so here is the related log excerpt on site A:
Handshake for peer did not complete after 5 seconds, retrying (try 16)
Wireguard: Sending handshake initiation to peer ((einval))
Wireguard: Handshake for peer did not complete after 5 seconds, retrying (try 17)
Handshake for peer did not complete after 5 seconds, retrying (try 20)
Handshake for peer did not complete after 20 attempts, giving up
