queue PCQ
[admin@MikroTik] /queue type> pri
 0 name="default" kind=pfifo pfifo-limit=50
 1 name="ethernet-default" kind=pfifo pfifo-limit=50
 2 name="wireless-default" kind=sfq sfq-perturb=5 sfq-allot=1514
 3 name="synchronous-default" kind=red red-limit=60 red-min-threshold=10
   red-max-threshold=50 red-burst=20 red-avg-packet=1000
 4 name="hotspot-default" kind=sfq sfq-perturb=5 sfq-allot=1514
 5 name="STEP_1" kind=pcq pcq-rate=64000 pcq-limit=50
   pcq-classifier=dst-address pcq-total-limit=179200
 6 name="STEP_2" kind=pcq pcq-rate=32000 pcq-limit=50
   pcq-classifier=dst-address pcq-total-limit=92000
 7 name="default-small" kind=pfifo pfifo-limit=10
[admin@MikroTik] /queue tree> print
 0   name="TREE_1_1" parent=global-out packet-mark=css,htm,js,php,xml
     limit-at=0 queue=STEP_1 priority=4 max-limit=0 burst-limit=128k
     burst-threshold=64k burst-time=5s
 1   name="TREE_2_1" parent=global-out packet-mark=gif,jpg,png limit-at=0
     queue=STEP_2 priority=5 max-limit=0 burst-limit=92k burst-threshold=32k
     burst-time=5s
 2   name="TREE_2_2" parent=global-out packet-mark=swf,bmp limit-at=0
     queue=STEP_2 priority=6 max-limit=0 burst-limit=92k burst-threshold=32k
     burst-time=5s
 3   name="TREE_2_3" parent=global-out packet-mark=bin,cab,dat,dll,inf,zip
     limit-at=0 queue=STEP_2 priority=7 max-limit=0 burst-limit=92k
     burst-threshold=32k burst-time=5s
 4   name="TREE_ALL" parent=global-out packet-mark=all limit-at=0 queue=STEP_2
     priority=8 max-limit=0 burst-limit=92k burst-threshold=32k burst-time=5s
the packet-mark is detect in layer7. I want all other packet not marked, limited be TREE_ALL. But in the TREE_ALL limited all packet, not only packet not marked :confused: :confused: :confused:
what is the solution
You should post your mangle rules as well, and … i guess you are in the wrong forum.
Try posting it on the beginners or general forum.
you still need to marked the other packet there`s no way you can control the traffic using queue tree without packetmark
also you need unchek the passtrough option for each marked packet
I want to do is:
(html, css, js) set limits for 1Mbps, priority = 1, DLS1
(jpg, gif, png) set limits of 512Kbps, priority = 2, DLS1
(swf, bmp) set limits for 128kbps, priority = 3, DLS1
(bin, cab, dat, dll, inf, zip) set limits for 92KBps, priority = 4, DLS2
(everything else) set limits for 92KBps, priority = 5, DLS2
I have two DSL lines, I want the first 3 on a line and the last two on the other line DLS
which is the easiest way to do this ???
