hi
i have upgraded toe the ROS V6RC6 but the queue tree does not seem to be working
it was setup using
http://wiki.mikrotik.com/wiki/Basic_traffic_shaping_based_on_layer-7_protocols
was working fine till V 5.22
can any one help??
check the queue parent…
issue resolved there is no parent global-in and global-out in ROS v6
it’s merged to a single entry global
Thanks to Mikrotik support Ticket#2013010266000016
i think queue tree is not prioritizing the traffics as it should be
all the statics for bytes transferred is 0
If global-in and global-out are now gone and replaced with just global, then how can we set different queue rates for children on egress and ingress without the parent globals?
Also, this page should be updated to remove the global-in and global-out now.
