i am absolutely newbie on routeros and may be its a simple problem, but i can’t find a solution right now so i am asking here. i have internet connection with 4mbit syncron. there are 5 pcs in the lan. now is the problem when one user is downloading from the web all others are waiting. i solved that with a simple queue, for each ip one queue. that works fine, but is it possible to dynamically assign the bandwith to the user if no one is using the connection? so i have 5 queues now, each one have 1mbit. i want to assign more speed to the clients if there is no one using the internet connection. how can i do that?
thanks
max
