Queues
i am using radius authentication with pppoe clients. if the authentication process is successfully the clients gets a queue signed by the radius. now i get a new proxy server with 2 lines for them. now i want basically give the user more speed through the proxy, but the rule based on the radius authentication should also work in the future.
is there any possibilty?
thx max
You cna create a rule that matches data coming from the Proxy system. This rule has to say at the top of the list, so you will need a script to do that :slight_smile:
