QUICK EP06-A setup
It took me WAY TOO LONG to get this running.
Every post about the EP06 was way too detailed about options and commands but no practical details.
With the help of Emils in support, I was able to get this up and running with NO tape and NO pc setup.
Below is the summary of getting this card running in about a minute.
After the second reboot... the card SHOULD just show up under /int/lte
BTW: Install ROS 7.1beta5
Some comments in 's
/interface/lte/settings/set mode=serial
/system reboot
[Wait for reboot]
/system/serial-terminal usb1 channel=2
[Ctrl-A is the prefix key]
ATI
Quectel
EP06
Revision: EP06ALAR02A08M4G
OK
at+qcfg="usbnet",2
OK
[CTL-A Q] [get out of terminal]
/interface/lte/settings/set mode=auto
/system reboot
All information you have in this Quectel EP06-E and wAP R ac (RBwAPGR-5HacD2HnD) - MikroTik
Check my scripts to fast setup all possible CA combination , Bands , And dome useful stuff.
scripts-20210311–2140.rsc (10.9 KB)
import scripts-20210311–2140.rsc
very important info, @Sib, you also have some scripts for the quectel EM160? I am preparing the rbm11g
I create few one and for 160/502 are in progress for one person. Write me at Telegram and that way will be easier to follow that.
About forum, please create a new thread insted of hijack other’s in future.
I wrote in this post because the only way to contact you, I tried several times in telegram but the account seems off, I will delete the post if you think it is not relevant.
ps:I just wrote you on telegram
End of this OffTipic here.
Telegram works, I have 2mth offline time…
Now it’s in progress. I create a scripts for EM160 and EM50x/EG50x series. You can write again at Telegram, I not found chat with your nick.
You can monitor my KB from my signature, I will publish final version of scripts but if you have some idea then write to telegram.
hey,
i have the same issue
nop... my card EP06-A do not show up.... do i need to downgrade to to 1 beta5 ?
i am on7.9RC1
if i do /interface print
i get
NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R ether1 ether 1500 1598 2028
1 wlan1 wlan 1500 1600 2290
but not LTE interface
if i do
/port print
i get
nothing...no ports
if i do /system resource usb print
i get
DEVICE VENDOR NAME SPEED
0 1-0 Linux 5.6.3 ehci_hcd RB400 EHCI 480
but i suppose to get
2 1:4 Quectel, Incorporated UMTS/HSPA Module 480 Mbps
i am so frustrated :frowning:
or what is the deal... i am giving up :frowning:
Ok, so the only way I made it to work was
Tapping off the 4 pins that USB3.0 use
So looks like the Wap series only support USB2
And the SXT are USB3 PCIm capable
Can someone confirm this?
PD.
Is MT going to add M.2 slots to their LTE router boards?
The high end 5G modules do not use PCIm but the M.2 interface
