Trying to create a wireless ptp bridge (indoor, short distance) with two of the above routers. Have upgraded to 6.7.
As soon as I use webfig or winbox quickset function, the router is disconnected and I cannot reconnect. Winbox detects the router on the local segment, but it cannot connect to it.
Which settings in Webfig/Quickset did you change, before losing the connection? It’s possible that you were connected to the device over the wireless interface, and when you changed it’s mode, you were disconnected.
