Radius Attributes from Access-Reject OR Redirect URL
Hi, is it possible to pass AVP’s from Access-Reject to HotSpot? The goal is, use information from AVP in Access-Reject to build dynamic redirect url (using External Web server Auth). I tried to check if $(error) or $(error-orig) available on redirirect URL, but they are blank. Also tried to use $(radius), they are also not passing.
my test code
<head><title>...</title></head>
<body>
$(if chap-id)
<noscript>
<center><b>JavaScript required. Enable JavaScript to continue.</b></center>
</noscript>
$(endif)
<center>If you are not redirected in a few seconds, click 'continue' below<br>
$(if error)<br /><div style="color: #FF8080; font-size: 9px">$(error)</div>$(endif)
$(if error-orig)<br /><div style="color: #FF8080; font-size: 9px">$(error-orig)</div>$(endif)
<tr><td align="right">connected:</td><td>$(radius<25>)</td></tr>
<tr><td align="right">connected:</td><td>$(radius25)</td></tr>
<tr><td align="right">connected:</td><td>$(radius<25>-<0>)</td></tr>
<tr><td align="right">connected:</td><td>$(radius25-0)</td></tr>
<tr><td align="right">connected:</td><td>$(radius<18>)</td></tr>
<tr><td align="right">connected:</td><td>$(radius18)</td></tr>
<tr><td align="right">connected:</td><td>$(radius<18>-<0>)</td></tr>
<tr><td align="right">connected:</td><td>$(radius18-0)</td></tr>
<form name="redirect" action="$(error)" method="post">
<input type="hidden" name="mac" value="$(mac)">
<input type="hidden" name="ip" value="$(ip)">
<input type="hidden" name="username" value="$(username)">
<input type="hidden" name="link-login" value="$(link-login)">
<input type="hidden" name="link-orig" value="$(link-orig)">
<input type="hidden" name="error" value="$(error)">
<input type="hidden" name="error-orig" value="$(error-orig)">
<input type="hidden" name="chap-id" value="$(chap-id)">
<input type="hidden" name="chap-challenge" value="$(chap-challenge)">
<input type="hidden" name="link-login-only" value="$(link-login-only)">
<input type="hidden" name="link-orig-esc" value="$(link-orig-esc)">
<input type="hidden" name="mac-esc" value="$(mac-esc)">
<input type="submit" value="continue">
</form>
<script language="JavaScript">
   document.redirect.submit();
</script></center>
</body>
</html>
My Access-Reject Contains different VAR (Radius Server is flexible, i can play with any AVP’s on reply)
Reply-Message : “https://wifilogin.company.com
Thank you in advance.
