RADIUS (IAS) HotSpot Authentication Problem
I have RB 1000 handling Internet access, two IPIP tunnels, 140 L2TP VPN connections to remote locations with ADSL, PPTP for “RoadWarriors”, and now I am trying to enable HotSpot on one of the Ethernet ports.
Everything woks fine if I create user on the router, but when I try to authenticate via IAS it does not work.
IAS currently authenticates PPTP connections so I did not try to configure it as it is suggested in http://wiki.mikrotik.com/wiki/How_to_setup_up_RADIUS_for_use_with_MikroTik_-_By_Ramona because I am afraid that it will spoil currently working connections.
Where is the difference in authenticating PPTP and Hotspot users?
Where is the problem?
Any Ideas?
Satman
Thanks for “all the help”, I did it by myself.
