Radius manager and MIkrotik
Hallo all.
I’m using DMA Radius manager (RM) on a Mikrotik WAN, many Highsites. All is well and working without issues.
However, I have a little project which beats me.
In RM, under services, if I change bit rate to 0, and add it manually in the ACP 'Custom RADIUS attributes it works fine, but I cannot add the “Total-Max-Limit”.
My idea is to supply a service, for instance, 2Mbps/2Mbps. But that would result in a 4Mbps pipe, the way RM configures the NAS. I want it to be a 2Mbps pipe.
Any ideas please?
Are you sure that “Total-Max-Limit” is a supported value?
Please post RADIUS log (on Mikortik) using this parameter.
No, not sure. I did not see it anywhere on forums, discussions.
Which is very strange, cause it is a very valid issue for me. I need to get the ‘pipe’ specified in order to prevent double-up bit-rates! :slight_smile:
Regards.
PS: The person from DMA said I should ask Mikrotik for the answer, as he did not have it… :frowning:
“Total-Max-Limit” seem not a valid generic or Mikrotik custom RADIUS attribute.
Have you checked on Mikrotik Manual?
http://wiki.mikrotik.com/wiki/Manual:RADIUS_Client#Supported_RADIUS_Attributes
Send mail to Mikrotik support.
# MikroTik Attributes
VENDOR          Mikrotik        14988
BEGIN-VENDOR    Mikrotik
ATTRIBUTE       Mikrotik-Recv-Limit             1   integer
ATTRIBUTE       Mikrotik-Xmit-Limit             2   integer
ATTRIBUTE       Mikrotik-Group                  3   string
ATTRIBUTE       Mikrotik-Wireless-Forward       4   integer
ATTRIBUTE       Mikrotik-Wireless-Skip-Dot1x    5   integer
ATTRIBUTE       Mikrotik-Wireless-Enc-Algo      6   integer
ATTRIBUTE       Mikrotik-Wireless-Enc-Key       7   string
ATTRIBUTE       Mikrotik-Rate-Limit             8   string
ATTRIBUTE       Mikrotik-Realm                  9   string
ATTRIBUTE       Mikrotik-Host-IP                10  ipaddr
ATTRIBUTE       Mikrotik-Mark-Id                11  string
ATTRIBUTE       Mikrotik-Advertise-URL          12  string
ATTRIBUTE       Mikrotik-Advertise-Interval     13  integer
ATTRIBUTE       Mikrotik-Recv-Limit-Gigawords   14  integer
ATTRIBUTE       Mikrotik-Xmit-Limit-Gigawords   15  integer
ATTRIBUTE       Mikrotik-Wireless-PSK           16  string
ATTRIBUTE       Mikrotik-Total-Limit            17  integer
ATTRIBUTE       Mikrotik-Total-Limit-Gigawords  18  integer
ATTRIBUTE       Mikrotik-Address-List           19  string
ATTRIBUTE       Mikrotik-Wireless-MPKey         20  string
ATTRIBUTE       Mikrotik-Wireless-Comment       21  string
ATTRIBUTE       Mikrotik-Delegated-IPv6-Pool    22  string
ATTRIBUTE       Mikrotik_DHCP_Option_Set        23  string
ATTRIBUTE       Mikrotik_DHCP_Option_Param_STR1 24  string
ATTRIBUTE       Mikortik_DHCP_Option_Param_STR2 25  string
ATTRIBUTE       Mikrotik_Wireless_VLANID        26  integer
ATTRIBUTE       Mikrotik_Wireless_VLANIDtype    27  integer
ATTRIBUTE       Mikrotik_Wireless_Minsignal     28  string
ATTRIBUTE       Mikrotik_Wireless_Maxsignal     29  string
# MikroTik Values
VALUE           Mikrotik-Wireless-Enc-Algo            No-encryption                  0
VALUE           Mikrotik-Wireless-Enc-Algo            40-bit-WEP                     1
VALUE           Mikrotik-Wireless-Enc-Algo            104-bit-WEP                    2
VALUE           Mikrotik-Wireless-Enc-Algo            AES-CCM                        3
VALUE           Mikrotik-Wireless-Enc-Algo            TKIP                           4
END-VENDOR      Mikrotik
