radius manager
i get radius manager from DMAsoftlab(.com) but i never success to install it. i use the tutorial but it never working too. Freeradius with mikrotik it’s not connected and i try to used NTRadping it’s not working too. Would u like to give me some example to configured it. my radius manager it’s under nat.
thx :cry:
What do u mean it doesn’t connect???, just set in the radius menu, then all are clear in there. just decide what is radius use for(ppp, hotspot,…), and ip the radius server, that’s all man…, don’t forget the port too
:laughing:
yes, i’ve do it. but it’s not working. if i try to connected the internet my radiusmanager it’s not working.
Try to use MikroTik User Manager, User Manager is RADIUS based management system integrated to the RouterOS package, it has very easy configuration interface.
Here you can find instructions how to start use User Manager,
http://wiki.mikrotik.com/wiki/User_Manager
ikrar,
i think you will have fast luck..!, when you install userman as radius server, cos now userman complete with manual at wiki page and little time to make config manage for your user.
last time we started it without manual like now. :cry:
but we are happy with it so fast and easy, that's right as sergejs suggestion.
good luck...!
regards
Hasbullah.com
if i’m used userman is working well but if i’m make radius server it always not working “radiusd not responding” :unamused:
Yeah, I bougth the same software: Radius manager, I installed it succesfully, but then when it came time to test it, the radius server would recibe the data from mikrotik, but mikrotik would not recibe the data form the Radius server, in order to fix this issue, you have to firt establish a connection with the Radius server to the mikrotik, if you are using hotspot in mikrotik, you have to log in to the hotspot first, if you are using pppoe, you must first make a pppoe link.
and then… bualla¡¡¡ it works.
thank you it’s working now, i’ve incorrect configuration in clients.conf.
thanks a lot
