Hello All,
We’re in the process of setting up a hotspot. We would like to sell users a limited amount of time, after which they would need to come and buy more before they can log on again.
I believe the RADIUS attribute I need to pass to the AP is Max-Session-Time. However, the manual says
Max-Session-Time > - maximum session length (uptime) the user is allowed to
So I’m only guessing it’s meant to finish along the lines of ‘log in for’.
Unfortunatley, the Max-Session-Time attribute doesn’t appear to be declared in any of the RADIUS dictionaries I have looked at (the ones that come with FreeRADIUS, and the ones pointed to from http://www.mikrotik.com/docs/ros/2.9/guide/aaa_radius).
Would anybody be able to tell me:
- Whether this is indeed the attribute I’m after
- Whether it is supported on the RB532
- What its attibute number and type (integer?) are so I can add them to my dictionaries.
I found a similar post from Nov 2005 at http://forum.mikrotik.com/t/max-session-time/3858/1 That poster was able to use the Session-Timeout attribute - unfortunatley, this doesn’t meet my needs (as the user can log straight back in again with the same username/password pair).
Thanks in advance.
Edit: RB532 running ROS2.9.27 on Firmware 1.13
