Hello everybody!I want to do it a DHCP server that controlled by a Radius
I read about it, need download and install user manager,but where can i found the user manager on Mikrotik homepage?
Thank you for your answers
“ALL PACKAGES”, not the single package.
Sorry,can you give me a link,because i could not found
Thank you
No, I can’t give you a direct link because you haven’t even told us what device you have.
Anyway, go to the downloads page http://www.mikrotik.com/download
Choose your device from the dropdown.
Then, put your cursor over “zip file”. Notice the filename is called “all_packages”.
That is what you need.
Thank you for your help,i downloaded all packages,i have got a RB 750 GL,so if i need for example user manager,only this npk package need to install
Yes, just drag the one file usermanager into the files and reboot. Just the one file out of the zip (userman.npk) is all you need to drag over.
Thank you,for your help
Thank you,i need this!!
