Hi, I had configured the usermanager in a CCR1009-8G-1S follow instructions found in several pages and everything seems set, but when try a to login it always register a log line indicating “Login failed RADIUS server is not responding”.
The packages are the same version 6.34.6, and seems ok, see images attached.Incoming has been enable and disable on port 1700 with no success.
Any idea of where how to solve this? thanks in advance.
https://s31.postimg.org/4z7nmhijb/image.png
https://s31.postimg.org/v8sq5a4gn/image.png
https://s31.postimg.org/7rw9srthz/image.png
hi
set IP on Ethernet port than you don’t use it and use it for connectivity hotspot with usermanager
I found it sometimes happen when your secret in your radius server doesn’t match the one you set in user
manager.
Also like the previous guy said, use a different interface, you can create a bridge interface with no ports assigned to it and give it ip 192.168.81.1/32 for example
I have created a video just last night on how to setup a basic hotspot, maybe you want to check it out.(its also my first ever video with voice)
https://www.youtube.com/watch?v=QnSuS88Np_s
Feel free to comment if I left something out of the video
I have a RB2011 router
I waas on 6.36.4 and all was working very well include radius server (usermanager)
When update to Version 6.37.1, problem with radius server not responding start.
radius ip adress :127.0.0.1 = fail
radius ip adress : 192.168.1.1 (hotspot server ip adress) = work but fail after a couple of days.
When go back to : 127.0.0.1… works a time but fall again.
What is the problem?
I then have to uninstall my router and reinstall (netinstall) version 6.36.4 and all works again perfectly without any problem.
I have been through all the posts on the forum and nothing helps.
There is a problem in 6.37.1 userman package?
Please could someone help with this problem. ![]()
I have installed user manager and it works fine but after a period of 8 hours its stop allowing the users to login, due to which i have to again allow user to use winbox login without time period and date criteria.
Can someone help me on this where could be the problem in any setting.
Hy..!
I have also same error after some time or day user manager show error radius not responding at the moment
What can I do ???
I like user manager option
the user manager is not a reliable radius server its the small radius server for few users and configurations
Thanks for reply
Can you help out about the data limits in PppoE user. Some user are every time download media files. I want to set user 30GB monthly limit
Hotspot is working fine and have option…
You can Limit the Data usage in user profile. Under Limits.
