I have a CRS112-8P-4S switch with version 7.20.4 and a RADIUS server with a certificate that only have the CN with the hostname of the server, no IP address references. The switch is “pointing” in the RADIUS settings to the IP address of the server, how can I use the name of the server instead? From Winbox I can only see that I can insert an IP address, the domain, but not the hostname. Is there any workaround that I can do?
Thank You and kind regrads
