RB 1000 Upgrade RAM to 1GB?
HI
Can the SODIMM RAM on RB 1000 be upgraded to 1GB?
I’d appreciate any comments thx!
Yes,
I’m using the 2 gig version on a couple RB1000’s on my network. The 1 gig version should work fine though.
Any DDR2 667 or faster SODIMM should work..
1 gig - http://www.newegg.com/Product/Product.aspx?Item=N82E16820134546
2 gigs - http://www.newegg.com/Product/Product.aspx?Item=N82E16820134549
-Gerard
Gerard, your routerboard see whole 2 gb?
i have just installed 2 gb and i see only 1,5
[admin@MikroTik] /system resource> pr
        uptime: 1m10s
        version: "3.23"
        free-memory: 1539956kB
        total-memory: 1556168kB
        cpu: "e500v2"
        cpu-count: 1
        cpu-frequency: 1333MHz
        cpu-load: 0
        free-hdd-space: 39268kB
        total-hdd-space: 61440kB
        write-sect-since-reboot: 143
        write-sect-total: 155774
        bad-blocks: 0
        architecture-name: "powerpc"
        board-name: "RB1000
i’m using kingston 2gb PC2-5300 SODIMM memory.
With 1 gb i don’t see any problem.
Apparently
What’s new in 3.19:
*) reduced maximum supported memory for RB1000 to 1.5Gb (was 1.75Gb);
wow! ok, fine thanks!
this is due to the hardware design, nothing we can do about it now
which can be the reason to add more RAM on RB1000?
more PPPOE sessions to manage?
If you need something beyond what the RB1000 can handle, v3.27 is stable and has fully working multi-cpu support now.
Basically pick any standard dell or IBM server that has some decent processing power and a hardware warrenty and you’re set :slight_smile:
more ram can be used for larger queue buffers, for proxying in RAM etc.
